- Thank you received: 14304
Product Details after checkout!
can u tell if we can take CVV number with card code n expiry date n check card holder on the bases as without cvv or cvvc ..its not secure any can know my cards number n expiry.
I don't understand your question for CVV.
1) card images should not be static it should be like u want to pay through visa card or master card or anyother...
2) Secondly, The card security code (CSC), sometimes called Card Verification Data (CVD), Card Verification Value (CVV or CVV2), Card Verification Value Code (CVVC),are different terms for security features for credit or debit card transactions, providing increased protection against credit card fraud.
2. You can activate an option for that on your authorize.net account. Again, that screen is on authorize.net so most of it can only be controlled by the options on authorize.net's end. You should contact authorize.net support if you can't find it in your authorize.net account.
For example, if you sell your products by length or by m², you can create one or two custom fields of the table "item" via the menu Display->Custom fields so that they appear on your product pages and you will be able to use the value entered by users in the quantity price calculations.
can i achieve that support like this in cost calculation. as i am facing a lot iof issues....Like cost is adding for first product if without checking out if continue shopping it doesn't add that cost.....
2)Regarding card validation code that option is checked in payment methods settings but still not taking CVC at the time of payment.....
3)Regarding registration while checking out how can i remove this "Additional Information" title if i dont want any extra fields while registration
2/ It's written in the documentation that the CVV option of the plugin is ONLY for the AIM API. But you're using the SIM API and HikaShop cannot control the CVV for it. As I already said, you need to contact authorize.net support for that.
3/ You need to edit your translation file via the interface in the tab Languages of the config: www.hikashop.com/download/languages.html#modify
first I hve send the value from cart table to order_product like this:
$orderProduct->order_product_name = $product->product_name;
$orderProduct->order_product_code = $product->product_code;
$orderProduct->order_product_price = @$product->prices[0]->unit_price->price_value+$product->cart_product_support ;
and after wards here trying to send same to new field order_support see if it is correct and you may guide to add it directly to order_full_price.
$order->order_discount_code = @$cart->coupon->discount_code;
$order->order_currency_id = $cart->full_total->prices[0]->price_currency_id;
$order->order_full_price = $cart->full_total->prices[0]->price_value_with_tax;
$order->order_shipping_price = @$cart->shipping->shipping_price_with_tax;
$discount_price = 0;
$order->order_support=$product->cart_product_support;
am i editing ryt file :
administrator/components/com_hikashop/extensions/plg_hikashoppayment_authorize/authorize.net
want to add that extra cost in total..it shoul add this static value....why not so...
"x_amount" => round($order->cart->full_total->prices[0]->price_value_with_tax+'100',(int)$currency->currency_locale),
by:
$order->order_full_price = $cart->full_total->prices[0]->price_value_with_tax=$cart->full_total->prices[0]->price_value_with_tax+$product->cart_product_support;
so that the total of the order is correct in the database for the order. Then, you won't have to change the total in the payment plugin.
for ex:
$175+$10= $185
$175+$10=$185
$4999+$10=$5009
total shoul be : $5379
tht ways its showing $5359
dint added for two more added for only one..
$support_total = 0;
foreach($cart->products as $product){
$support=$product->cart_product_support;
$quantity_s=$product->cart_product_quantity;
$support_total+=$support*$quantity_s;
$order->order_full_price = $cart->full_total->prices[0]->price_value_with_tax=$cart->full_total->prices[0]->price_value_with_tax+$support_total;
