Products and own characteristics
15 years 3 months ago - 15 years 3 months ago #22412 by maxgag51
Hi Nicolas, I have a new problem.
I added the characteristics to products of my customer; of course, because it's a shoes brand, I added the numbers.
Well when Hika shows products, without any choice, appears this!
Isn't Ok.
Also, if I change measure, Hika shows a photo smaller ! .
The cart is correct. .
If I change the characteristics like this: ,
I get this:
This isn't good.
and cart is like this:
I would this, on the page products
and this on the page cart
Is't possible! How?
Thanks in advance
Massimo
Last edit: 15 years 3 months ago by maxgag51. Reason: images not correct
15 years 3 months ago #22420 by nicolas
You need to keep that option turned on. Also, if you don't want to show the size on the product name on the product page, you need to edit the file show of the view product like that:
www.hikashop.com/fr/support/forum/2-gene...-the-cart-.html#9818
15 years 3 months ago - 15 years 3 months ago #22543 by maxgag51
Perfect but this problem remains:
enter into product show:
change char (the image is smaller than before):
15 years 3 months ago #22561 by nicolas
Could you give the URL of that page ?
It's because you're missing some CSS but I can't tell precisely what without seeing the page with my browser.
15 years 3 months ago #22640 by maxgag51
www.inabox.it/gt (the site is still in production).
Choice english language, shop on line, spring/summer, Alice (is only model with measures, at the moment).
I set width thumbnail to 300, this is correct for product list and first product page.
Don't works correctly if you change the measures.
If you want go to admin panel this is to access:
15 years 3 months ago #22646 by nicolas
Please try to add such CSS code:
.hikashop_product_main_image_thumb img{
height: 300px !important;
width: 492px !important;
15 years 3 months ago #22653 by maxgag51
