product add error
15 years 2 months ago - 15 years 2 months ago #24160 by resif
product add error was created by resif
Warning: file_put_contents(/home/esyaliko/public_html/media/com_hikashop/upload/thumbnail_100x120/ayakli_servis_tabagi.jpg) [function.file-put-contents]: failed to open stream: Permission denied in /home/esyaliko/public_html/libraries/joomla/filesystem/file.php on line 304
file.php 304
$ret = file_put_contents($file, $buffer);
Last edit: 15 years 2 months ago by resif.
15 years 2 months ago #24165 by nicolas
Replied by nicolas on topic Re: product add error
It's a problem of access rights. You should fix the permissions of the folder media/com_hikashop/upload so that Joomla can write files in it.
15 years 2 months ago #24183 by resif
Replied by resif on topic Re: product add error
i made full write permission still same error.... image missing http://www.hikashop.com/media/kunena/attachments/legacy/images/ekrangoruntusu5.png
15 years 2 months ago #24185 by nicolas
If php says it can't write the file, it's because the permissions don't allow it to... file_get_contents is not lying :)
If you can't fix your permissions issue, you should ask your hosting company for help about that problem. They should be able to fix it.
15 years 2 months ago #24195 by resif
ok thank you...
Time to create page: 0.214 seconds
