Overriding Hikashop classes for custom features
- brainforge
15 years 4 weeks ago #28425
by brainforge
Overriding Hikashop classes for custom features was created by brainforge
In helper.php line 760 would it be possible to check for the existance of a class file in either the site or admin template locations?
The purpose would be to reduce the risk of any class customisations a developer may have made getting accidently overridden during a Hikashop upgrade.
I.E. change code
to something like this:
This idea came about while thinking of possible solutions to the following topics:
11199-coupons-and-discounts
27448-coupons-for-specific-products
Another idea was for a couple of new functions which could be called by a plug-in:
onBeforeVoucherAdded
onAfterVoucherAdded
These would be invoked in loadAndCheck function of discount.php something like this:
Any other ideas if how this moght be achieved?
I.E. change code
if(!class_exists($className)) include_once(constant(strtoupper('HIKASHOP_'.$group)).$class.'.php');
if(!class_exists($className)) {
$classfile= JPATH_SITE . DS . 'templates'.DS.$app->getTemplate().DS.'classes'.DS.'com_hikashop'.DS.$class.'.php'
if (file_exists($classfile)) {
// Add some way of checking if custom class is compatible with installed Hikashop version
// If not then produce an error
include_once($classfile);
else {
$classfile= JPATH_ADMINISTRATOR . DS . 'templates'.DS.$app->getTemplate().DS.'classes'.DS.'com_hikashop'.DS.$class.'.php'
onAfterVoucherAdded
function loadAndCheck($coupon_code,&$total,$zones,&$products,$display_error=true){
$coupon = $this->load($coupon_code);
if (...onBeforeVoucherAdded... exists) {
$beforeResult = ...->onBeforeVoucherAdded($coupon,$total,$zones,$products,$display_error);
if ($beforeResult === FALSE) return null;
if (is_object($beforeResult)) return $beforeResult;
$result = $this->check($coupon,$total,$zones,$products,$display_error);
if (...onAfterVoucherAdded... exists) {
$afterResult = ...->onAfterVoucherAdded($result,$coupon,$total,$zones,$products,$display_error);
if ($afterResult === FALSE) return null;
if (is_object($afterResult)) return $afterResult;
return $result;
15 years 4 weeks ago #28444
Replied by nicolas on topic Re: Overriding Hikashop classes for custom features
The current code already allow you to override all the classes in HikaShop.
You can just create a joomla system plugin and implement the class in the plugin file. Since the code checks that the class does not already exists before loading the file in HikaShop and since the system plugins are always loaded first, you will be able to achieve just what you're looking for.
So I don't feel like that code is needed actually.
Regarding the addition of events on the coupon checking code, that's a nice idea even though I doubt that it will be used a lot. We'll implement something for that (not like that).
- brainforge
15 years 4 weeks ago #28492
by brainforge
Replied by brainforge on topic Re: Overriding Hikashop classes for custom features
Looks like a system plug-in along the following lines will do the job:
class plgSystemMyclasses extends JPlugin {
public function onAfterRoute() {
if (JRequest::getVar('option') == 'com_hikashop') {
if (!class_exists('hikashop')) {
include(JPATH_ADMINISTRATOR . DS . 'components/com_hikashop/helpers/helper.php');
include(__DIR__ . DS . '/class/myclasses.php');
15 years 4 weeks ago #28501
Yes. You could even do simpler:
Do not have that code in your plugin file and directly have your classes there.
When joomla starts loading, it will include your plugin file and your classes will be instantiated automatically and since it won't find your plugin class it won't try to call it but your classes will already be there for HikaShop to use.
