Linking to product variants from cart
15 years 2 weeks ago #29679
by tjsan
Linking to product variants from cart was created by tjsan
I have created a new product, let's call it "widget". Widget has two characteristics, "blue" and "red". I have also created two related products "foo" and "bar", which are in an upublished category.
On the product page for widget, the related pruducts foo and bar are displayed.
When the widget is added to the cart, it is actually product widget:blue or widget:red that is added and when the user clicks on the product from within the cart, the variant product page is displayed - not the original product.
However, the variants are not linked to the related products so they do not appear on the product page.
Either, the link from the cart should go to the parent product instead of the variant OR the variant should also have the ability to specify related products.
What do you think?
What do you think?
15 years 2 weeks ago - 15 years 2 weeks ago #29700
by tjsan
Replied by tjsan on topic Re: Linking to product variants from cart
I got this to work the I want by modifying the cart view as follows:
Replace this:
<tbody>
<?php
$k = 0;
$this->cart_product_price = true;
$group = $this->config->get('group_options',0);
foreach($this->rows as $i => $row){
if(empty($row->cart_product_quantity)) continue;
if($group && $row->cart_product_option_parent_id) continue;
With this:
<tbody>
<?php
$k = 0;
$prodlink_id = $row->product_id;
foreach($this->rows as $j => $r) {
if ($row->cart_product_parent_id == $r->cart_product_id) {
$prodlink_id = $r->product_id;
continue;
My only worry is that this might cause performance problems if there are a large number of products - what do you think?
Replace this:
<tbody>
<?php
$k = 0;
With this:
<tbody>
<?php
$k = 0;
continue;
Last edit: 15 years 2 weeks ago by tjsan.
15 years 2 weeks ago #29718
Replied by nicolas on topic Re: Linking to product variants from cart
No problem with performances for that modification.
That indeed something we didn't think of.
The ideal solution would be to handle that case on the product page so that related products are displayed even if it's the variant id in the URL.
