- Thank you received: 3
Variations issue on product page
14 years 10 months ago #36279
by uteco
Variations issue on product page was created by uteco
The product page does show more Variations than programmed if there are more than one characterictics on the same product page.
for example: you have three characteristics for the same product. But not all combinations are for use.
Even if you have made the right selection on the Variation page you still can make any combination on the product page at the front end even it the combination was NOT in the variations available.
example
variation 1. length= 3, color= green, size= 45
variation 2. length= 3, color= black, size= 50
variation 3. length= 4, color= black, size= 45
characteristics
length
,4
color= green, black
size= 45,50
the selection of length= 4, color= green, size= 50 is selectable even if there was no variation made for it!
example
characteristics
length
,4color= green, black
size= 45,50
14 years 10 months ago #36322
Replied by nicolas on topic Re: Variations issue on product page
That's indeed the case. The dropdowns have to show you all the values, otherwise, you wouldn't be able to select all your variants.
However, even though you can select it, you won't be able to buy it because that will be detected by the system and the add to cart button should not be displayed.
Time to create page: 0.042 seconds
