Authorize.net Direct Post Method (DPM)?
11 years 9 months ago #187085 by 3by400
Joomla version: 3.3.6
Hikashop version: HikaShop Business: 2.3.5
HI! I know this is a REALLY old thread, but I wanted to find out where the Authorize.net DPM development currently stands? Its shown as an API option in the plugin but selecting the DPM option does not appear to use the DPM method. It actually seems to redirect to the SIM method.
Thanks for any insight you can provide!
-Bridgette
3by400, Inc.
3by400.com
Websites that Work, Marketing that Matters
11 years 9 months ago #187087 by Jerome
Did you look at the plugin Authorize in the HikaShop payment plugins interface ?
11 years 9 months ago #187167 by 3by400
Hi Jerome -
Yes, sorry for not being clearer. I was referring to the "HikaShop Authorize.net payment plugin". I see the DPM method as an API option in the "HikaShop Authorize.net payment plugin" but when DPM is selected the frontend result is a redirect to an Authorize.net-hosted payment form.
3by400, Inc.
3by400.com
11 years 9 months ago #187220 by Jerome
DPM has been added in May 2012.
In DPM mode, the plugin adds an iframe in his "end" page.
11 years 9 months ago #187345 by 3by400
Is there a certain way the checkout workflow needs to be configured for that result? When I select the DPM API in the plugin, the result on the frontend is a redirect to authorize.net at the end step.
3by400, Inc.
3by400.com
11 years 9 months ago #187353 by Jerome
There is no configuration to do in the checkout.
The "authorize_end" view starts with this code
<?php if ($this->payment_params->api == 'dpm' && @$this->payment_params->iframe){ $url=urlencode(base64_encode(json_encode($this->vars))); ?> <iframe name="frame" scrolling="auto" height="1000" width="660" Frameborder="no" src="<?php echo $this->vars["x_relay_url"].'&iframe='.$url;?>"></iframe> <?php return; } ?>
And in the onAfterOrderConfirm function of the plugin, the variable "iframe" is set to "1" if the API is not "AIM".
So unless you modified or create an override for the view, the iframe should be displayed.
11 years 9 months ago - 11 years 9 months ago #188120 by 3by400
We haven't modified the plugin or created any custom views.
I'll dig into the code and figure out why it isn't working and let you know what I find.
3by400, Inc.
3by400.com
Last edit: 11 years 9 months ago by 3by400.
11 years 9 months ago - 11 years 9 months ago #188763 by 3by400
Originally the end step was redirecting to A.net and using the SIM method even though I have DPM configured in the plugin.
I changed this:
<?php if ($this->payment_params->api == 'dpm' && @$this->payment_params->iframe ){ $url=urlencode(base64_encode(json_encode($this->vars))); ?>
To this:
<?php if ($this->payment_params->api == 'dpm'){ $url=urlencode(base64_encode(json_encode($this->vars))); ?>
And, now the end step is not redirecting, but instead its correctly trying to load the iframe on the page. The issue now is that the iframe is empty.
3by400, Inc.
3by400.com
11 years 9 months ago #188766 by Jerome
Just for the notice ; you made an assignation in a IF instead of testing the variable.
So, your modification might put an iframe but I don't think that it is the most appropriate fix.
About the empty iframe ; you should use the browser inspector in order to check the iframe size and the iframe target link.
11 years 9 months ago - 11 years 9 months ago #188850 by 3by400
Hi Jerome -
Thank you for your response. Ok, ok bad example. My point is that this isn't resolving to true:
- @$this->payment_params->iframe.
I do see in authorize.php that if the api is not == 'aim' then iframe is set to 1, but in authorize_end its not 'true'.
Also, I did actually review the iframe code via my browser inspector (ie, firebug). The target URL looks correct, but the form is not populated in the body of the frame.
target URL:
index.php?option=com_hikashop&ctrl=checkout&task=notify&notif_payment=authorize&tmpl=component&lang=en&Itemid=465&iframe=long_encoded_gobbidy_gook
iframe size: 660 x 1000
3by400, Inc.
3by400.com
11 years 9 months ago #189718 by Mohamed Thelji
We just fixed an issue regarding the Authorize.net DPM mode, you should edit the "plugins\hikashoppayment\authorize\autorize.php" file and change these lines :
else{ $this->payment_params->iframe = 1; $vars = $this->_loadStandardVars($order); $viewType = 'end'; $vars["x_show_form"] = 'PAYMENT_FORM'; if(@$this->payment_params->notification){ $vars["x_relay_response"] = 'TRUE'; $vars["x_relay_url"] = HIKASHOP_LIVE.'index.php?option=com_hikashop&ctrl=checkout&task=notify&notif_payment=authorize&tmpl=component&lang='.$this->locale.$this->url_itemid; } $vars["x_fp_sequence"] = $vars["x_invoice_num"]; $vars["x_fp_timestamp"] = time(); $vars["x_fp_hash"] = hash_hmac("md5", $vars["x_login"] . "^" . $vars["x_fp_sequence"] . "^" . $vars["x_fp_timestamp"] . "^" . $vars["x_amount"] . "^" . $vars["x_currency_code"], $this->payment_params->transaction_key); if(!empty($this->payment_params->x_logo_url)){ $vars['x_logo_url']=$this->payment_params->x_logo_url; } $this->vars = $vars; }
By :
else{ $vars = $this->_loadStandardVars($order); $viewType = 'end'; $this->payment_params->iframe = 1; $vars["x_show_form"] = 'PAYMENT_FORM'; if(@$this->payment_params->notification){ $vars["x_relay_url"] = HIKASHOP_LIVE.'index.php?option=com_hikashop&ctrl=checkout&task=notify&notif_payment=authorize&tmpl=component&lang='.$this->locale.$this->url_itemid; $vars["x_relay_response"] = 'TRUE'; } if($this->payment_params->api == 'dpm') { $vars["x_relay_url"] = HIKASHOP_LIVE.'index.php?option=com_hikashop&ctrl=checkout&task=notify&notif_payment=authorize&x_po_num=' . (int)$order->order_id . '&tmpl=component&lang='.$this->locale.$this->url_itemid; } $vars["x_fp_sequence"] = $vars["x_invoice_num"]; $vars["x_fp_timestamp"] = time(); $vars["x_fp_hash"] = hash_hmac("md5", $vars["x_login"] . "^" . $vars["x_fp_sequence"] . "^" . $vars["x_fp_timestamp"] . "^" . $vars["x_amount"] . "^" . $vars["x_currency_code"], $this->payment_params->transaction_key); if(!empty($this->payment_params->x_logo_url)){ $vars['x_logo_url']=$this->payment_params->x_logo_url; } $this->vars = $vars; }
The following user(s) said Thank You: 3by400
11 years 9 months ago #189860 by 3by400
Thank you Mohamed and Jerome -
We will apply these changes and report back!
3by400, Inc.
3by400.com
11 years 9 months ago #190115 by 3by400
I've posted our update to Kevin's (essential) forum post. We are working with Kevin to assist him with his Joomla and HikaShop configuration.
3by400, Inc.
3by400.com
