[SOLVED] : breadcrumb trail for cats in products
14 years 9 months ago - 14 years 5 months ago #37620
by rikatos
[SOLVED] : breadcrumb trail for cats in products was created by rikatos
Hi.
I have a sugggestion which has bugged me for quite a while.
I have products located in different categories, this is one the the great things about hikashop how you make the product then just link it into as many different categories as you like. Theres is one problem though.
An example is needed
If I have a category called
Leisure..liferafts...Accessories
and another category called
Commercial..liferafts...Accessories
The base products (liferafts) are different but the accessories are all the same, so good old hikashop makes this very easy for me to link the accessories to both categories, excellant ! BUT on the category list they look identical
yes I know there is a ID at the end, but tbh that doesnt really realte anything to me in the real world as I dont know the IDs
Last edit: 14 years 5 months ago by rikatos.
The following user(s) said Thank You: uteco
- Thank you received: 1
14 years 9 months ago #37662
by many-feathers
Replied by many-feathers on topic Re: SUGGESTION : breadcrumb trail for cats in products
I definitely subscribe to this! I logged in to make this same suggestion, just to see it rikatos beat me to it!
Shouldn't really be difficult to implement I guess?
14 years 9 months ago - 14 years 9 months ago #37664
by Jerome
Replied by Jerome on topic Re: SUGGESTION : breadcrumb trail for cats in products
In order to summarize and understand, you want that the name displayed in the category listing (your screenshot) contains the "full name" ?
Like: "Leisure / liferafts / Accessories" instead of "Accessories" ?
Last edit: 14 years 9 months ago by Jerome.
14 years 9 months ago #38000
by many-feathers
Yes, that would be great to be able to identify the correct category when multiple categories with the same name are selected.
Thank!
Thank!
14 years 9 months ago #38070
Replied by nicolas on topic Re: SUGGESTION : breadcrumb trail for cats in products
It's in the todo list.
14 years 9 months ago - 14 years 9 months ago #38090
by rikatos
Replied by rikatos on topic Re: SUGGESTION : breadcrumb trail for cats in products
Sorry took so long to reply, yes nicolas, exactly that
and thanks for putting on the to do list
Last edit: 14 years 9 months ago by rikatos.
14 years 7 months ago #48153
by rikatos
Hi there
I was just checking back on this to do. I am now in need of this quite bad as my shop has 6 main categories with subcategories that could all be the same name ! it is difficult to know which of the sub categories is one to remove or add at the moment.
14 years 7 months ago #48222
We'll look at that for next release
The following user(s) said Thank You: rikatos
14 years 7 months ago #48237
by many-feathers
That's good news! We're also waiting for this...
Thanks!
14 years 7 months ago #48243
by rikatos
Aye it is
I am so looking forward to it, kinda sad really !
14 years 5 months ago #52763
by rikatos
Replied by rikatos on topic Re: [SOLVED] : breadcrumb trail for cats in products
marked as solved as its implemented in the latest hikashop, and its all I ever wanted so THANKS guys
