Product is not clickable
14 years 9 months ago #39001 by Scheinbacher
Hello Hika-fans
please help me with this challenge:
-The product listed can not be click. However I listed the item via category or and product modul, the product dont show.
plexiglas-deko.de/index.php/de/plexiglas...rylglas-farblos-klar
Thanks for your advice.
14 years 9 months ago #39024 by Jerome
Replied by Jerome on topic Re: Product is not clickable
Please check your HikaShop menu configuration ("Display > Content menus").
There is an option in "Parameters for products" called "Link to the product page".
Otherwise, in the general HikaShop configuration, tab "Display" there is the same option in the fieldset "Default parameters for products".
14 years 9 months ago #39103 by Scheinbacher
Jerome
I already have done these setting.
Do you have another ideas?
Thank You
14 years 9 months ago #39194 by nicolas
You should go in the menu Display->Content modules and edit the module with the id 117. There, you will find the same option that you can turn on to have your products clickable.
14 years 9 months ago #39292 by Scheinbacher
Thank You.
Now it is clickable!
14 years 5 months ago #54165 by jeremy1128
I am having the same problem. I followed the steps listed but I do not see a module with ID 117 inside Display->Content Modules. All I see is 168, 165 and 164. Please help if you can.
travellersridge.com/merchandise
Thanks,
Jeremy
14 years 5 months ago #54168 by Jerome
"117" was the ID for the module in Scheinbacher's website.
Nicolas gives this ID because it was easier for Scheinbacher to find his module.
You have to edit an HikaShop category module.
Your page " travellersridge.com/merchandise/category/12-horse " have a product which is not clickable.
Opening the source code ofo the page, you can found into : "hikashop_category_information_module_168".
It means that you have to edit the module "168" and configure the option.
14 years 5 months ago #54179 by jeremy1128
That was exactly it. Thank you so much for clearing that up and helping me out! I really appreciate it.
Have a great day.
