Problem with options
- diosneptuno
14 years 9 months ago #40195
by diosneptuno
Problem with options was created by diosneptuno
I have a problem with options, for example if I have an option with a product not has characteristics no problem, but with products that have characteristics the option shown in the product but not added to the shopping cart.
What is the problem?
14 years 9 months ago #40380
Replied by nicolas on topic Re: Problem with options
We don't have that problem on our end.
Could you give a link to the product page where you have the problem so that we can see that ?
- diosneptuno
14 years 9 months ago #40435
by diosneptuno
Replied by diosneptuno on topic Re: Problem with options
The link to the product: www.alimentacionmascotas.com/alimentacio.../category_pathway-20
When you change the option feature, not added to the shopping cart.
Thank you
Thank you
14 years 9 months ago #40608
I can see only option choice for your option. You must have created a characteristic without values or with only one value.
You should create a characteristic with several values and then add your characteristic to the option product.
You can follow the instructions here and you should be able to have a product with options working properly:
www.hikashop.com/en/support/documentatio...ct-form.html#options
- diosneptuno
14 years 9 months ago - 14 years 9 months ago #40671
by diosneptuno
I have proved the demo hikashop, and I've added two characteristics in the product www.demo.hikashop.com/index.php?option=c...y_pathway=23&lang=en This product has several options.
I have added two colors as characteristic, and the same occurs that happens to me, when added to the shopping cart not are added options.
Andreu
Andreu
Last edit: 14 years 9 months ago by diosneptuno.
14 years 9 months ago #40891
That was a bug in one of the first builds of the current release. We put up a new build since then. Please download it again on our website and install it over your current build and it should work.
I've just updated the master of the demo website (the demo website will be updated within 1 hour) to that build and can no longer reproduce the problem
The following user(s) said Thank You: diosneptuno
- diosneptuno
14 years 9 months ago #40894
by diosneptuno
I have updated to the new version and now everything works perfect.
Thank you.
Andreu
Thank you.
Andreu
