Logging out issue
14 years 8 months ago #44461
by kizza2
Logging out issue was created by kizza2
When i click on the log out button in my shopping cart i get the error message
Secure Connection Failed
An error occurred during a connection to www.trendcommunications.com.au .
SSL received a record that exceeded the maximum permissible length.
(Error code: ssl_error_rx_record_too_long)
I contacted the people who host my site and they advised me to get in contact with the developers of the shopping cart.
14 years 8 months ago #44579
Replied by nicolas on topic Re: Logging out issue
Such error is not related to "the shopping cart" but to the configuration of the server...
For example:
stackoverflow.com/questions/119336/ssl-e...-long-and-apache-ssl
The only thing I can tell you from our point of view is to turn off the "force SSL on checkout" option so that HikaShop doesn't redirect to the SSL version of your website and you will circumvent the problem. But if you want to use SSL and fix that error, you will have to see that with your hosting.
For example:
The following user(s) said Thank You: kizza2
