UPS plugin not showing in front end!
14 years 7 months ago #46962 by debcampos
I configured everything for my UPS plugin, entered all key, username and password but my shipment methods still don't show in the front end! I followed all the documentation and the plugin is published. I don't know what else to do!
14 years 7 months ago #47132 by nicolas
I've checked your configuration and it looks ok. Normally, HikaShop should display an error message with the reason explaining why it cannot display the shipping methods.
However, your website is not displaying error messages like it should so it's hard to say.
We will need an FTP access to your website in order to trace down the problem.
14 years 7 months ago #47214 by debcampos
No problem, i just sent the ftp access through your contact form. I await for your reply! :)
14 years 7 months ago - 14 years 7 months ago #47229 by cs4u18
debcampos wrote: I configured everything for my UPS plugin, entered all key, username and password but my shipment methods still don't show in the front end! I followed all the documentation and the plugin is published. I don't know what else to do!
This is an absolutely superb shopping cart for Joomla. Much easier and more intuitive than Virtuemart, OSCommerce, Zen Cart and many others. I'm enjoying it so far. We don't have that many items in our cart so I'm copying them over manually from Virtuemart. But I'm having the same problem with the UPS shipping plugin. I configured everything but the UPS shipping method doesn't show up in the front end. Only the Manual plugin shows up. Screenshots attached. Please help and thank you for such a great shopping cart!
Last edit: 14 years 7 months ago by cs4u18.
14 years 7 months ago #47245 by nicolas
The problem comes from the dimensions of the product based on the traces in put in the plugin. because they are either too low, not there, or with a different unit that the main dimension unit/unit in the ups plugin. However, since the user account you sent doesn't work anymore I couldn't change it.
14 years 6 months ago #47275 by robertf
I have added all the UPS info, weights (no dimensions) and i get this error on checkout. I also disabled the manual shipping. What am I doing wrong?
Robert
14 years 6 months ago #47315 by cs4u18
I checked to ensure that all units for dimensions and weights are configured properly in the System and in products. Still no luck getting the UPS plugin to show in the front end. Any suggestions would be greatly appreciated. Thanks again.
14 years 6 months ago #47324 by debcampos
Hi Nicolas, what user account are you talking about? cs4u18 or me? I too checked the dimensions and everything is there but my plugin doesn't show in the front end! I need this plugin working ASAP, please help. I sent yesterday the lo gin info.
14 years 6 months ago #47403 by nicolas
@robertf : You need to have dimensions in your products. That's required by UPS.
@cs4u18: I see that your post code starts with a dash. Please make sure that your post code is valid. Also, unpublish the manual shipping plugin. That way, UPS will display error messages. Otherwise, it won't.
@debcampos: Yes, I'm talking about the user account you sent yesterday. When I tried to use it, it didn't work anymore. It seems that it was deactivated/removed. Could you double check it please ?
14 years 6 months ago #47769 by debcampos
Hi Nicolas, i just emailed my correct login info, please let me know how to make this plugin work... thanks!
14 years 6 months ago #47954 by nicolas
I checked your website and indeed, the problem came form the dimensions of your product.
You just hadn't set any dimensions for it...
I've added some random dimensions and it's working now for that "Night Gown" product.
The following user(s) said Thank You: debcampos
14 years 6 months ago #48068 by debcampos
Hi Nicolas, Thank you. Now i understand that the weight and dimensions are for the shipping package, not the product itself! :)
