- Thank you received: 1
Product Navigation
- sonjaclerc
14 years 6 months ago #47316
by sonjaclerc
Product Navigation was created by sonjaclerc
Hi all
I tried to find a way for having a "previous"/"next" link in the product page.
Is there a way to achieve that?
Thanks in advance for help
14 years 6 months ago - 14 years 6 months ago #47350
by Xavier
Replied by Xavier on topic Re: Product Navigation
Hi sonjaclerc,
In the last release of HikaShop, this option is present.
To active it, just go in HikaShop > System > Configuration > Display.
Under "Default parameters for products" Check "Yes" for the option: "Show shortcuts to other category products ".
Last edit: 14 years 6 months ago by Xavier.
The following user(s) said Thank You: sonjaclerc
- sonjaclerc
14 years 6 months ago #47606
by sonjaclerc
Replied by sonjaclerc on topic Re: Product Navigation
Hi Vavier
This works... Thanks for help.
Another question about that...
Is possible to navigate only through main products if they have options?
Thanks for your reply
sonjaclerc
sonjaclerc
14 years 6 months ago #47621
Replied by nicolas on topic Re: Product Navigation
There is no option for that.
14 years 6 months ago #47994
by tpatsiouras
Replied by tpatsiouras on topic Re: Product Navigation
Thank you very much Nicolas... That saved me from a lot of nagging...
Theodore
Theodore
Time to create page: 0.102 seconds
