Menu links not working for product listing
14 years 6 months ago #47795 by freemanbob
Hi All,
I migrated to a new test server:
  • exportd hikashop tables
  • ftped the content from media/com_hikashop to the new server
  • installed upgrade to 'business'
and proceeded to set up a menu for the products.
Every thing within the hikashop seems fine, I can see all the products etc.
The joomla menus work for everything other than hikashop components?
The path name that is created seems to add an additional level, what I mean is instead of:
www.mysite.com/index.php/categoryname
I get www.mysite.com/index.php/Banners/categoryname I then get an error because the link in the menu is pointing to something that does not exist.
I have looked everywhere to find the reference to the Banners folder but there is none in any of the products, nor the categories nor the hikashop config so how is the additional folder called Banners being added by either joomla or hikashops. I should mention again that the menus work for all other linked items except hikashop components.
Please advise
Bob
[attachment:1]hikashopmenus.PNG[/attachment]
[attachment:2]hikashopmenusSettings.PNG[/attachment]
[attachment:3]joomlamenusettings.PNG[/attachment]
14 years 6 months ago #47873 by nicolas
Your images were not attached to your post.
That would help to see what you did. A link to the page would also help.
14 years 6 months ago #47904 by freemanbob
I have since set up a new category in hikashop and a new product to see if the imported data might have been effected somehow but the locally created category and product produce the same results (a spurrious folder called Banners in the link pathway).
shiningbrightly.co.uk/redlion/index.php/pub-grub-home the menu on the left is the hikashop product listings except the 'Pub Grub Home' link.
see attached images:
14 years 6 months ago #47905 by freemanbob
14 years 6 months ago #47906 by freemanbob
14 years 6 months ago #47907 by freemanbob
14 years 6 months ago #47908 by freemanbob
14 years 6 months ago #47909 by freemanbob
14 years 6 months ago #47913 by freemanbob
14 years 6 months ago #47914 by freemanbob
14 years 6 months ago #47915 by freemanbob
14 years 6 months ago #48000 by nicolas
Here are some possibilities:
1. You don't use the default SEF system of joomla and the SEF extension you're using has cached the old SEFed URLs. Clearing the cache of the extension might help (if you use sh404sef for example).
2. It might be related to the SEF product/category name options in the main tab of the configuration of HikaShop. You should check them.
3. What if you delete a menu and create a new one identical to the old one ? That might solve the problem...
14 years 6 months ago #48118 by freemanbob
I got it working by setting joomla SEF to 'no' but I want to use SEF how can this be fixed.
I have included the setting for both hika and joomla, these settings produce the error:
When I turn the joomla SEF of it work, Why would Hikashop not sync with joomla to show SEF paths?
I await your solution.
sincerely
freemanbob
14 years 6 months ago #48121 by freemanbob
I just realised one of my posts has posted 9 times, it was not my intention to do that, sorry.
I tried to delete but don't seem to have to ability to delete my own posts?
Please feel free to delete all but one.
sincerely
freemanbob
9 years 10 months ago #258504 by mahwaz
I had this problem and found a very easy solution: Just restored an "older" and "valid" .htaccess file. this file was changed (I think by joomla) and links were broken. Now everything is OK.
I know this is an old topic, just want to help guys who will face this problem in the future, like me!
Sincerely,
Mohammad.
