Issue with Terms in IE
14 years 6 months ago - 14 years 6 months ago #49331 by BarBomb
Whenever i check off the Terms and Conditions checkbox in Internet Explorer, Hikashop acts as if I didnt check it off. It throws the error that you would get if you tried to continue without checking off the terms box. Please asisst, Thanks!
You can see what I am talking about via the link below:
barbomb.com/index.php/shows/sponsor-a-show/hilltop-tavern
Last edit: 14 years 6 months ago by BarBomb.
14 years 6 months ago #49380 by nicolas
Replied by nicolas on topic Re: Issue with Terms in IE
That comes from a bug in your template which replaces the checkboxes to put its own. Turn that off in the template's options and it will work.
