RESOLVED: Understanding Variants 3 - Alias Field
14 years 6 months ago - 14 years 6 months ago #50959 by scottshort
Using Alias Field to reduce non-existant variants:
My first trial product ended up having over 2000 variants, most of which were variants that did not exist [no product matching that variant]. So I am working on understanding what I need to change in order to reduce this number of non-existing variants.
On Characteristics setup page, each characteristic has name and alias.... can I have more than one characteristic called 'Color' and then use the alias field to distinguish between products: eg. ballerina, sandal, dress, etc. to avoid excessive uneeded variants??
Example:
Name: Color, Alias: Ballerina Colors
Name: Color, Alias: Sandal Colors
Name: Color, Alias: Dress Colors
In this way each product page will have 'Color' as a characteristic while on admin side, I will be able to keep them separate. And doing it this way would avoid excessive variants that would exist if colors for all three products were entered into the same characteristic.
Is my thinking correct here? Do you recommend using alias fields in this way?
Last edit: 14 years 6 months ago by scottshort. Reason: RESOLVED
14 years 6 months ago #51094 by nicolas
YES, the goal of the alias field is exactly for that: be able to distinguish it in the back end while keeping the same name on the front end.
The following user(s) said Thank You: scottshort
