Fatal error - Export products
- Micke_skane
14 years 6 months ago - 14 years 6 months ago #51275
by Micke_skane
Fatal error - Export products was created by Micke_skane
I've tried to Export products but got this message:
Fatal error: Allowed memory size of 67108864 bytes exhausted (tried to allocate 4 bytes) in /storage/content/22/137022/joomla.XXX.se/public_html/libraries/joomla/database/database/mysql.php on line 652
What does this mean?
Error points to:
* Method to fetch a row from the result set cursor as an object.
* @param mixed $cursor The optional result set cursor from which to fetch the row.
* @param string $class The class name to use for the returned row object.
* @return mixed Either the next row from the result set or false if there are no more rows.
* @since 11.1
protected function fetchObject($cursor = null, $class = 'stdClass')
return mysql_fetch_object($cursor ? $cursor : $this->cursor, $class); }
/Micke
Error points to:
* @since 11.1
/Micke
Last edit: 14 years 6 months ago by Micke_skane.
- Thank you received: 1778
14 years 6 months ago #51279
by Mohamed Thelji
Replied by Mohamed Thelji on topic Re: Fatal error - Export products
Hello Micke,
It means that the memory requirements exceed the default memory limit, I think that you can maybe solve this by adding a line like this to the server’s php.ini file:
Hope this will help you a little.
memory_limit = 12M
- Micke_skane
14 years 6 months ago #51283
by Micke_skane
Replied by Micke_skane on topic Re: Fatal error - Export products
Hey Mohamed,
Thanks for you replay but where can I find the ini-file?
14 years 6 months ago #51288
by Mohamed Thelji
It depends of your hosting company, so you'll have to ask them, but first how many product do you want to export ?
- Micke_skane
14 years 6 months ago - 14 years 6 months ago #51294
by Micke_skane
I've seen the information about PHP in Joomla and it says:
memory_limit 64M
So there should be enough of memory...(or not!)
I think it's between 1000-1500 products I want to Export.
memory_limit 64M
14 years 6 months ago #51298
by Mohamed Thelji
The 12M was an example you can maybe change your "memory_limit" value to 128M because you're exporting a big number of product.
14 years 6 months ago #51386
Replied by nicolas on topic Re: Fatal error - Export products
1500 products can amount to a lot of memory resources. I suppose that if you export only 100 products you don't have any problem right ?
- Micke_skane
14 years 6 months ago #51393
by Micke_skane
Hey,
I've upgraded to a buisness-level where the website is placed and that gives me 256MB as memory and solved the problem.
Micke
Micke
