Add to cart display pop up issue
14 years 5 months ago #53268 by londonstudio
Hello all,
I turned the Add to cart display popup on, it works the pop up is displayed in full.
The problem is the pop only displays for less than a second and then closes its self.
With out the user choosing to continue shopping or go to the checkout.
Do you know how to fix this?
14 years 5 months ago #53274 by nicolas
Look at the options just below that option. You will find this one: Notice popup display time
14 years 5 months ago #53282 by londonstudio
Thanks, how do I style the popups css?
14 years 5 months ago #53361 by nicolas
Normally, it's like full pages. In the front end CSS file of HikaShop via the Display tab of the configuration.
14 years 5 months ago - 14 years 5 months ago #53368 by londonstudio
Sorry Nicolas, What is it called? I couldnt see it in there.
I just want to make the font plain (not bold) and change the green colour to a blue to match the rest of my site.
Last edit: 14 years 5 months ago by londonstudio.
14 years 5 months ago #53414 by nicolas
Search for hikashop_messages in the front end CSS file of Hikashop and you will find the CSS related to the message in the popup.
The following user(s) said Thank You: londonstudio
14 years 5 months ago #53431 by londonstudio
Got it, Thanks.
13 years 8 months ago - 13 years 8 months ago #93754 by donzo
I have another issue with the pop up where it displays the homepage in the popup and not the confirmation?
Though, I have seen the correct popup once? But now it displays the homepage in the popup window?
scubazone.bulletdesign.com
Last edit: 13 years 8 months ago by donzo.
13 years 8 months ago #93898 by Xavier
Have you edited the view "product / quantity", or "checkout / notice" ?
13 years 8 months ago #93902 by donzo
Hi Xavier, no, I haven't
Ive removed all custom .htaccess, and switched of akeeba admin tools, thinking that might be effecting things?
13 years 8 months ago #94059 by Xavier
The link previously given redirect to a "hello world" page, so I can't check the problem.
13 years 8 months ago #94085 by donzo
ah, yes, i had to put the .htaccess back in. Its displaying now.
13 years 8 months ago #94098 by donzo
Ive just noticed that this doesn't happen if "Global Configuration - SEO Settings - Search Engine Friendly URLs" is switched off.
thanks
13 years 8 months ago #94178 by nicolas
There is something on your website which redirects the link of the notice popup:
scubazone.bulletdesign.com/online-shop/c...otice/tmpl-component
to your index page when SEF is turned on:
I'm not sure why but that's the reason. One case where that could happen is if you have a redirection alias setup in a SEF component like SH404SEF.
13 years 8 months ago #94186 by donzo
I have checked and I dont have anything like that, except the custom .htaccess, which I have tried stripping down and made no difference.
Is this a clue, this problem does not happen when you add products to the cart from within a category, it only seems to happen when you try and add a product from the online shop landing page?
So...
scubazone.bulletdesign.com/online-shop , select a product and add to cart = problem.
scubazone.bulletdesign.com/online-shop/c...s/51-fin-accessories , select and add product from with category page and its ok ??
Any help ??
13 years 8 months ago #94188 by donzo
I found the problem! That last clue, was useful.
It was the "Menu" setting in the content module for the shop landing page, it was set to 'online shop', I changed to 'categories' and now its ok.
thanks
Time to create page: 0.109 seconds
