[SOLVED]Problem with Alpha User Points
- diosneptuno
14 years 5 months ago - 14 years 5 months ago #53986
by diosneptuno
[SOLVED]Problem with Alpha User Points was created by diosneptuno
Hello
I am using for some time Alpha User points and everything has worked correctly.
But since the last update I have a problem, when I change the order to "Sent" items that the user has won with the purchase lose points.
For example, if a user makes a purchase and wins 10 points when I change the order to "Shipped" these 10 points are removed.
What is the problem?
Screenshot: awesomescreenshot.com/08282knd2
Screenshot plugin Hikashop AUP: awesomescreenshot.com/02282ky58
Thank you.
Andreu
Thank you.
Andreu
Last edit: 14 years 5 months ago by diosneptuno.
14 years 5 months ago #53995
by Jerome
Replied by Jerome on topic Re: Problem with Alpha User Points
There is an option in the AlphaUserPoint plugin named "Gives Points on statuses".
In this field you have to list all valid statuses. If the order change to a status not listed, points would be removed.
When this field is empty, the plugin would just retrieve the "order confirmed status" from the HikaShop configuration.
My recommendation is (for a classical configuration): confirmed,shipped
The following user(s) said Thank You: diosneptuno
- diosneptuno
14 years 5 months ago #54033
by diosneptuno
Replied by diosneptuno on topic Re: Problem with Alpha User Points
Thank you very much, I had not seen this option.
Problem solved
Fantastic support!
Andreu
Problem solved
Fantastic support!
Andreu
