Show cats and products in HikaShop in a cool way!
14 years 5 months ago - 14 years 5 months ago #54345 by Hoang
Hi guys,
Skyline HikaShop Nested Accordion is a module of Joomla! that displays HikaShop categories as multilevel accordion menu. The accordion effect is written in native mootools javascript which is supported by Joomla! core so that there will be no javascript conflict when you use this module.
Try this here .
Thank you.
Last edit: 14 years 5 months ago by Hoang.
14 years 5 months ago #54375 by nicolas
That's great !
Thank you for sharing that !
14 years 4 weeks ago #73243 by ponygirl
is there any way to sort the catagories in alphabetical order????
14 years 4 weeks ago #73247 by nicolas
In hikashop categories listing modules, you can go in the hikashop options of the modules and select the ordering column and the ordering direction options for that.
14 years 4 weeks ago #73248 by ponygirl
Thanks Nicolas but i tried that and this is related to the Skyline Accordian Menu so probably not your area of support
The module installs fine but the category name order is out sync
$query->select('a.*')
->from('#__hikashop_category AS a')
->join('INNER', '#__hikashop_category AS b ON a.category_left BETWEEN b.category_left AND b.category_right')
->where('b.category_type = \'product\'')
->where('b.category_parent_id > 1')
->where('b.category_published = 1')
->order('a.category_left , a.category_ordering ')
14 years 4 weeks ago - 14 years 4 weeks ago #73249 by nicolas
You shoudl change:
->order('a.category_left , a.category_name')
Last edit: 14 years 4 weeks ago by nicolas.
14 years 4 weeks ago #73250 by ponygirl
Thanks again but i tried that and it did not work.
see attached. I have raised a support ticket with Skyline a few days ago but they are not as quick with giving support as you are :)
14 years 4 weeks ago #73251 by nicolas
Than I don't know. You'll have to wait for their answer.
The following user(s) said Thank You: ponygirl
