My price is showing half. I'm going mad!!
14 years 5 months ago #54545 by petepirate
On my site: www.telefoonwinkel-utrecht.nl/index.php/category/30-accus
You can see the price shows half the words and nr's.
What's wrong?
14 years 5 months ago #54555 by nicolas
The HTML code of that page is old HikaShop code.
It seems that you had edited the file "listing_div" of the view "product" via the menu Display>Views before updating HikaShop. Try to remove the customization and that should avoid that problem.
14 years 5 months ago #54559 by petepirate
I haven't edit anything...So I can't see how I can put the settings back in place.It must be something in the css i think...
Still going mad..
14 years 5 months ago #54563 by nicolas
Try to disable the "carousel" option or increase the "pane height" option of the module with the id 95 via the menu Display->Views.
The following user(s) said Thank You: petepirate
14 years 5 months ago #54590 by petepirate
I Disabled the caroucel and now its good. Thank you
