See product in Add to Cart Modal - How?
14 years 4 months ago #54757 by nowherenowhere
Hi Guys,
I've been busy working on a few ecommerce sites lately ad Hika is the best! I just love this component. Supprt is outstanding and its such a mind-leap from the other stuff...
But I have a small issue I really need some help with - though if I can figure it out before I get a reply I'll let everyone know.
What I want is for the product which has been "Add to Cart" to display in the modal window just below the 2 buttons (Notices) So I know I'm looking in the notices.php under checkout... Quesiton is - what code to I put and where?
Thank you
Brett
Believe in Better
14 years 4 months ago - 14 years 4 months ago #54819 by nicolas
Actually, in the popup, you don't know which product was added.
All you can do is load the cart and get the name of the product which was added the latest in the cart. Something like that:
$class = hikashop_get('class.cart'); $cart = $class->loadFullCart(); $max = null; foreach($cart->products as $product){ if($product->cart_product_modified>@$max->cart_product_modified){ $max = $product; } } if($max){ $class = hikashop_get('class.product'); $product = $class->get($max->product_id); echo $product->product_name; }
Last edit: 14 years 4 months ago by nicolas.
14 years 4 months ago #54867 by nowherenowhere
Hiya Nicolas,
Ah yeah I see how it's working and I've added the code - I can now see the product name... How can I pull more info from the cart though - it would be great if I could get a picture of the item, along with the name and the price - is that possible? I've tried grabbing some of the code from view > checkout > cart but its just breaking the thing - probably because my PHP syntax is poor/ faulty
Believe in Better
14 years 4 months ago #54952 by nicolas
Well, you can do like that:
foreach($cart->products as $product){ if($product->product_id!= $max->product_id) continue; echo $product->prices[0]->price_value; $image = reset($row->images); $height = $this->config->get('thumbnail_y'); echo $this->image->display($image->file_path,true,$image->file_name,'style="margin-top:10px;margin-bottom:10px;display:inline-block;vertical-align:middle"'); }
14 years 4 months ago #55399 by nowherenowhere
I think I'm doing something wrong here... From what I can see I replace the original snippet from foreach... but then nothing is being echoed back:
<?php
$max = null;
She's not working....
Believe in Better
14 years 4 months ago #55499 by nicolas
You should not replace it but add it to the other.
See, the $max variable which is used in the second piece of code I gave is initialized in the first piece of code I gave.
14 years 4 months ago #55509 by nowherenowhere
Unfortunately that also has some issues >
Take 1 >
<?php
$max = null;
$max = $product;
if($max){
Errors:
Strappy Chick2100
Warning: reset() expects parameter 1 to be array, null given in /home/content/97/9350797/html/templates/ds_2/html/com_hikashop/checkout/notice.php on line 44
Fatal error: Call to a member function display() on a non-object in /home/content/97/9350797/html/templates/ds_2/html/com_hikashop/checkout/notice.php on line 46
Take 2 >
<?php
$max = null;
$max = $product;
if($max){
Errors:
Strappy Chick2400
Warning: reset() expects parameter 1 to be array, null given in /home/content/97/9350797/html/templates/ds_2/html/com_hikashop/checkout/notice.php on line 43
Fatal error: Call to a member function display() on a non-object in /home/content/97/9350797/html/templates/ds_2/html/com_hikashop/checkout/notice.php on line 45
I dont know whats going on here....
Believe in Better
14 years 4 months ago #55581 by nicolas
Take1, the line:
should be:
$image = reset($product->images);
14 years 4 months ago #55642 by nowherenowhere
hmmm... Still no joy on this one
Here is my code:
<?php
$max = null;
$max = $product;
if($max){
here is the error:
Although on the positive side it is now showing price total I think
Believe in Better
14 years 4 months ago #55746 by nicolas
Ah yes, the image helper in not loaded on that view... You need to load it yourself like that:
$this->image = hikashop_get('helper.image');
14 years 4 months ago - 14 years 4 months ago #56853 by nowherenowhere
This is great I have it working nicely now - thank you. here is the working code so far:
<div id="modalcart"> <div class="modalmodel"> <?php $class = hikashop_get('class.cart'); $cart = $class->loadFullCart(); $max = null; foreach($cart->products as $product){ if($product->cart_product_modified>@$max->cart_product_modified){ $max = $product; } } if($max){ $class = hikashop_get('class.product'); $product = $class->get($max->product_id); echo $product->product_name; } ?> </div> <div class="modalprice"><strong>Price: </strong> <?php foreach($cart->products as $product){ if($product->product_id!= $max->product_id) continue; echo $product->prices[0]->price_value; ?> </div> <?php $this->image = hikashop_get('helper.image'); $image = reset($product->images); $height = $this->config->get('thumbnail_y'); echo $this->image->display($image->file_path,true,$image->file_name,'style="margin-top:10px;margin-bottom:10px;display:inline-block;vertical-align:middle"'); } ?> </div> </div>
I do still have one issue though... If I add a product with options ie. its a shoe site and you could select a black or grey or white shoe - when I add it - in the modal it has a bit of a freak out with the price... please see here > heelcrush.com/collection.html (Click Modern Crimp "BUY ME") Select a size and "BUY ME" in the modal that pops up the price is now crazy >> Price: 300.00000
Please help me :)
Believe in Better
Last edit: 14 years 4 months ago by nowherenowhere.
14 years 4 months ago - 14 years 4 months ago #56879 by nicolas
Change :
$class = hikashop_get('class.currency');
echo $class->format($product->prices[0]->price_value,$product->prices[0]->price_currency_id);
Last edit: 14 years 4 months ago by nicolas. Reason: fixing code
14 years 4 months ago #56892 by nowherenowhere
Nah Nicolas, shes not working m8... See here:
<div id="modalcart"> <div class="modalmodel"> <?php $class = hikashop_get('class.cart'); $cart = $class->loadFullCart(); $max = null; foreach($cart->products as $product){ if($product->cart_product_modified>@$max->cart_product_modified){ $max = $product; } } if($max){ $class = hikashop_get('class.product'); $product = $class->get($max->product_id); echo $product->product_name; } ?> </div> <div class="modalprice"><strong>Price: </strong> <?php foreach($cart->products as $product){ if($product->product_id!= $max->product_id) continue; $class = hikashop_get('class.currency'); echo class->format($product->prices[0]->price_value,$product->prices[0]->price_currency_id); ?> </div> <?php $this->image = hikashop_get('helper.image'); $image = reset($product->images); $height = $this->config->get('thumbnail_y'); echo $this->image->display($image->file_path,true,$image->file_name,'style="margin-top:10px;margin-bottom:10px;display:inline-block;vertical-align:middle"'); } ?> </div> </div>
I get this error:
Parse error: syntax error, unexpected T_CLASS in /home/content/97/9350797/html/templates/ds_2/html/com_hikashop/checkout/notice.php on line 48
Not sure what this all means is it because there are 2 variables called $class
Believe in Better
14 years 4 months ago #56923 by nicolas
Use that code instead:
The following user(s) said Thank You: nowherenowhere
14 years 4 months ago #56974 by nowherenowhere
Yeah that worked well thank you Nicolas :)
Here is the code for all the other peeps who need it >>
<div id="modalcart"> <div class="modalmodel"> <?php $class = hikashop_get('class.cart'); $cart = $class->loadFullCart(); $max = null; foreach($cart->products as $product){ if($product->cart_product_modified>@$max->cart_product_modified){ $max = $product; } } if($max){ $class = hikashop_get('class.product'); $product = $class->get($max->product_id); echo $product->product_name; } ?> </div> <div class="modalprice"><strong>Price: </strong> <?php foreach($cart->products as $product){ if($product->product_id!= $max->product_id) continue; $class = hikashop_get('class.currency'); echo $class->format($product->prices[0]->price_value,$product->prices[0]->price_currency_id); ?> </div> <?php $this->image = hikashop_get('helper.image'); $image = reset($product->images); $height = $this->config->get('thumbnail_y'); echo $this->image->display($image->file_path,true,$image->file_name,'style="margin-top:10px;margin-bottom:10px;display:inline-block;vertical-align:middle"'); } ?> </div> </div>
Believe in Better
13 years 2 weeks ago #130616 by janbartos24
Hello.
Is it possible to pass to the notice even the related products to the added one?
I can pass a module position to the popup but if i try to add related items module to this doesnot work (custom html in the module shows, so the module position added i functional)
13 years 2 weeks ago #130799 by Xavier
Do you have an error displayed ?
You can enable the Joomla debug mode, and set the error reporting to maximum to see from where the problem come.
