hikashop_social does not work
You made my day
Undak
just installed new plugin version you posted, but it seems not to solve the problem for me.
In my experience, the plugin don't work only for unauthenticated user
how can I fix?
regards
Fabio
Configuration:
Joomla: 2.5.9
Hikashop: 2.1.1
Hikamarket: 1.1.2
The plugin in HikaShop 2.1.0 is more recent than the plugin I posted 2 months ago.
You said that for authenticated users it works but not for unanthenticated one.
Do you have some cache activated in your website ?
I re-installed the complete package of hikashop professional. The problem still persists.
For example: www.insegnalo.it/catalogo-corsi-online/c...a-professionista-2-0
Yes, I use joomla progressive cache
I also installed this plugin to chache control and disable com_hikashop cache
extensions.joomla.org/extensions/core-en...formance/cache/17783
The strange thing is that if you load the page the first time it works, if you refresh the page no longer see the plugin
Is that clear?
Fabio
Configuration:
Joomla: 2.5.9
Hikashop: 2.1.1
Hikamarket: 1.1.2
I am sorry but I don't think that your cache system is really disabled for HikaShop pages.
The first time you see the right button, it was because the cache was not exists.
So the plugin was right called and it could change the tag by the html content.
The second time, the page was cached so, it render the cache page and does not call the system plugin.
i hace similar problem but more strange.
sometimes plugin Works , most of them {hikashop_social} and sometimes display wrong image and bad description
www.bonsai-hobby.com is my site
Which version of HikaShop do you have ? The 2.3.0 ? If not, thanks to update.
i am using the hikashop version : 2.2.3 and joomla 2.5.19 i will update the version to check if the problem still remain.thanks
check this link of my site:
bonsai-hobby.com/accesories_bonsai/product/64-accesories-2.html
after upgrade all of my photos have white border!!!!!!!!!!!!!!!!!!!! and the hikashop Social not work! :huh:
The fist time I see the page, the social button were there.
The second time, I got the tag.
I think you have a cache system somewhere ; in your Joomla or in your template.
To disable the cache, you can go in the Joomla configuration options.
Disable the Joomla cache plugin, and potentially any other installed cahce plugin or component.
Sometimes there is cache too in the template.
i disabled the system cache plugin of joomla and now Works fine!!!!!
thanks a lot
well we have a little problem , i disable cache and i have NEW problem... Social plugin Works but
take a look
bonsai-hobby.com/pot.html
i have 4 pages in this hikashop catergory... if i will go to last page (4) and after that page go to tanuki(etc) and after tanuki go to pot catergory, i will go to last page , not to First page!!!!!!!
The best I think is to edit the file "listing" of the view "product" via the menu Display>Views and add such code at the beginning:
i found this
components\com_hikashop\views\product\tmpl\listing.php
i put it First of all this code and after that i take an error...(can not display the page)
hikashop.com/support/support/documentati...ize-the-display.html
The line:
Probably due to the PHP tags, there must not be two following opening or ending tags.
Finally i found the listing.php
I insert the code at the beggining of file but nothing happens.
Are you sure you edited the view "product | listing" for the right template ?
In the views panel, you can use some filters (in the top right), the best is to select your front-end template so you will be sure to override the view for the right template.
take a look of these two images
Jerome,Xavier? did you find nothing?
