Disable add to cart button for some products
14 years 4 months ago #55622
by d4rkcloud
Disable add to cart button for some products was created by d4rkcloud
is there any way to hide the add to cart button for some product?
I'd like to have some product that i want to show online, but without the possibility to add it to cart.
Is it possibile?
Thanks!
Is it possibile?
Thanks!
- Thank you received: 1778
14 years 4 months ago - 14 years 4 months ago #55628
by Mohamed Thelji
Replied by Mohamed Thelji on topic Re: Disable add to cart button for some products
Yes, can for example :
- Set the quantity of your product to 0
OR
- Set the price of your product to 0
- Go to "Hikashop->System->Configuration->Display"
- Set the "Display 'add to cart' button for free products" to NO
Hope this will help you a little
OR
Last edit: 14 years 4 months ago by Mohamed Thelji.
14 years 4 months ago #55631
by d4rkcloud
Replied by d4rkcloud on topic Re: Disable add to cart button for some products
Ok, this could be a solution.
But what should i do if the customer asnwers me that he wants to see the price but not the cart...? :blink:
14 years 4 months ago #55648
by Mohamed Thelji
You should use the first solution, then the price will be displaid
The following user(s) said Thank You: d4rkcloud
14 years 4 months ago #55683
by d4rkcloud
Good!
Thank you! :woohoo:
Thank you! :woohoo:
