Pop up when changing order status
14 years 4 months ago #56434 by Boudewijn
On you're youtube example I saw that you would become a popup by changing the orderstatus.
I don't get this pop up. Do I need to activate or change something?
14 years 4 months ago #56480 by nicolas
If you don't get the popup, it means that you have a javascript error on your back end.
Could you look at the javascript error console of your browser for the error while doing it ?
14 years 4 months ago #56501 by Boudewijn
I've seen it. In my other browser it does give a popup.
I also use the pdf invoice creater from hika. Do I need to create the pdf myself or does the orderstatus change automaticly sends a pdf to the customer?
14 years 4 months ago #56539 by nicolas
When the order is confirmed, it will send the customer the "order status notification" email and that plugin will attache to it a PDF of the invoice automatically.
14 years 4 months ago #56568 by Boudewijn
Ok thank you Nicolas
