Product Code on Product Detail Page
15 years 9 months ago - 15 years 9 months ago #5683 by hdracing
Just wondering why the product code is displayed immediately after the product name on the product detail page. I was able to remove it on my test site, but forgot where I made the change. Is there a setting someplace that is causing this? I really don't want to modify the php files if there is a better way.
image missing http://www.highdesertracing.com/photos/1162988190_cvEFb-M.jpg
Thanks,
Ed
Last edit: 15 years 9 months ago by hdracing. Reason: Misspelled my own name!
15 years 9 months ago #5685 by nicolas
Normally, it should be hidden by default with the CSS in HikaShop:
.hikashop_product_code_main{
display:none;
Otherwise, you can add that CSS to your template CSS and the product code won't be displayed.
As a side note, if you edit the views of HikaShop via the menu Display->Views instead of modifying the files directly, HikaShop will save your modifications in an override file of your template so that you won't loose your modifications when you update HikaShop.
15 years 9 months ago #5686 by hdracing
Hmmm - Must be another IE quirk. I loaded up Firefox to find the code and the product code is not displayed in FF. Could there be a syntax or type problem somewhere that FF ignores but caused IE to choke?
Ed
15 years 9 months ago #5687 by hdracing
I added it to the bottom of template.css but it didn't change anything. Could it be something else?
Thanks,
Ed
15 years 9 months ago #5689 by nicolas
You need to clear your browser cache after modifying the CSS files as they are usually cached by it and thus you won't get the new version of the file.
15 years 9 months ago #5690 by hdracing
I did that but no change. I'll clear everything out and try again.
Ed
15 years 9 months ago #5691 by hdracing
Sorry, still no change.
Ed
15 years 9 months ago #5692 by nicolas
Could you give the URL of your website ?
15 years 9 months ago #5695 by hdracing
I'll send you a support email as you will need to login to see the HikaShop Menu item.
Thanks,
Ed
15 years 9 months ago - 15 years 9 months ago #5696 by nicolas
Mmm. I see that IE messes the parsing of the title on that page on your website. That's really strange since we don't have such issues on other websites.
I don't know what to tell you. I tried to search online but couldn't find a relevant answer. The easier will be to edit the view as explained above and remove the span of the product code.
Last edit: 15 years 9 months ago by nicolas.
15 years 9 months ago #5697 by hdracing
OK - That's how I fixed it in the first site where I tested HikaShop so I'll do that again.
Thanks for taking a look at the problem. I don't think I've used any Joomla component that has had such quick and responsive support! You're doing a great job.
Ed
Time to create page: 1.885 seconds
