Product Background Color
14 years 3 months ago #57735
by Raymee
Product Background Color was created by Raymee
I want the background colour of my product items to be white.
I have changed every content module and menu module I can see in the back end to white for the 'item box background color' but this is not changing the background of the product item.
Any help would be appreciated - I did play around with the "menu drop down list" and manually associated modules eg setting the module menu = to "Menu Item for Category listing Module 94" maybe this mucked it up.
Any help appreciated.
regards
regards
14 years 3 months ago - 14 years 3 months ago #57791
by Xavier
Replied by Xavier on topic Re: Product Background Color
Hi Raymee,
If you tried to change every content module/menu, I don't know from where the problem come from.
You can try to edit it by css, in HikaShop > Configuration > Display, edit the font-end css file, and add/edit the property:
You can see the FAQ here:
.hikashop_subcontainer{
background-color: #FFFFFF !important;
Last edit: 14 years 3 months ago by Xavier.
14 years 3 months ago #57946
by Raymee
Replied by Raymee on topic Re: Product Background Color
I ended up changing the css for .hikashop_product_page in line with the code above and that solved it.
