Update 1.5.8 and Problem during checkout
14 years 4 months ago #58315 by Kurt
Hello, I tried the version 1.5.8 update
This time, the trick to rename the file in 17mod_hikashop is failed.
My big problem is that no one can buy more.
There is always a message.
Please include your address or select from these
thanks and regards Kurt
14 years 4 months ago #58400 by nicolas
We will need more information in order to help you.
I don't know what trick you're talking about regarding "17mod_hikashop" ? Could you give information on that ?
Regarding the address, what does that mean ? You can't add address to users ? You can't select an existing address ? Could you give a link to your checkout so that we can see that ?
14 years 3 months ago #60111 by Kurt
Hi nicolas,
sorry for my late reply!
I name the file "mod hikashop" in "17mod_hikashop"
Because I'm having problems with links and images with the Joomla version 1.5, I just change to 2.5. Here was no problem to update Hikashop.
Unfortunately nobody can buy now because always an address must be entered.
But when I type an address it goes not on?
The new shop is located in the extra directory, and it takes time he is ready.
best regards Kurt
14 years 3 months ago #60183 by nicolas
Can you make sure that the "address_street2" field is unpublished via the menu Display->Custom fields.
Then, download again the latest version from our website and install it on yours.
That should hopefully solve the problem.
14 years 3 months ago #60217 by Kurt
the field "address_street2" gives not in my Custom fields.
I downloaded the new version from 08.08 but it does not work.
best regards kurt
14 years 3 months ago #60279 by nicolas
Then can you turn on the debug mode option of the joomla configuration and try to register again ?
That should display an error message.
