Stock level not displayed on productpage
14 years 4 months ago #58625 by Micke_skane
Hey,
How can I show the stock level on my productpage in Hikashop?
I've set the quantity to 1 for a product but it doesn't shows on the productpage.
Isn't this something that should been showed automatic?
The code that decides what should been showed on the productpage have I figured out should be this part:
if($this->row->product_quantity==-1){ ?> <div class="hikashop_product_stock"> <?php echo $this->cart->displayButton(JText::_('ADD_TO_CART'),'add',$this->params,$url,$this->ajax,'',$this->row->product_max_per_order,$this->row->product_min_per_order); }elseif($this->row->product_quantity>0){ ?> <div class="hikashop_product_stock"> <?php echo '<span class="hikashop_product_stock_count">'.JText::sprintf('X_ITEMS_IN_STOCK',$this->row->product_quantity).'</span><br/>'; $config =& hikashop_config(); if($config->get('button_style','normal')=='css'){ echo '<br />'; } if($this->row->product_max_per_order<=0 || $this->row->product_max_per_order>$this->row->product_quantity) $this->row->product_max_per_order = $this->row->product_quantity; echo $this->cart->displayButton(JText::_('ADD_TO_CART'),'add',$this->params,$url,$this->ajax,'',$this->row->product_max_per_order,$this->row->product_min_per_order); }else{ ?> <div class="hikashop_product_no_stock"> <?php echo JText::_('NO_STOCK'); $waitlist = $this->config->get('product_waitlist',0); if(hikashop_level(1) && ($waitlist==2 || ($waitlist==1 && !empty($this->element->product_waitlist)))){ ?> </div><div id="hikashop_product_waitlist_main" class="hikashop_product_waitlist_main"> <?php $empty=''; $params = new JParameter($empty); echo $this->cart->displayButton(JText::_('ADD_ME_WAITLIST'),'add_waitlist',$params,hikashop_completeLink('product&task=waitlist&cid='.$this->row->product_id),'window.location=\''.str_replace("'","\'",hikashop_completeLink('product&task=waitlist&cid='.$this->row->product_id)).'\';return false;'); } }?> </div>
14 years 4 months ago #58641 by Mohamed Thelji
You'll maybe find your answer there :
If you entered a quantity for your product, it should appear automatically on the product page along with the add to cart button. If you don't have the add to cart button, that would explain that you don't see the stock.
If you don't see the add to cart button, it's probably because you activated the "catalogue mode" option or deactivated the option "Display 'Add to cart' button" option in the Display tab of the configuration.
14 years 4 months ago - 14 years 4 months ago #58734 by Micke_skane
The Add to cart-button are there.
I'll look into the Config-tab to see if I missed something...
EDIT:
I've added a image of the configuration and productpage for the show of stocklevel for a product.
Last edit: 14 years 4 months ago by Micke_skane.
14 years 4 months ago - 14 years 4 months ago #58741 by Mohamed Thelji
Can you tell me what quantity did you set for your product ?
EDIT
Can you tell me if you have the line :
X_ITEMS_IN_STOCK="%s items in stock"
in your translation file in "Hikashop->System->Configuration->Language"
Last edit: 14 years 4 months ago by Mohamed Thelji.
14 years 4 months ago - 14 years 4 months ago #58742 by Micke_skane
On Productpage I set 1 as quantity, see orange mark for Productpage.
Isn't that right way to do it?
EDIT:
I've got this line:
NO_STOCK="Inte i lager"
X_ITEMS_IN_STOCK="%s produkter i lager"
14 years 4 months ago #58755 by Mohamed Thelji
Can you :
- Save your "show_default" and "quantity" file of your "product" view
- Use the Remove customization button for each file
and tell me if it works.
14 years 4 months ago #58762 by Xavier
Hi Micke_skane,
Do you have variants for this product ?
If yes, you have do edit the quantity of the variants.
14 years 4 months ago #58763 by Micke_skane
What ;)
Do you mean if I can save the files under "Display -> Views"?
So if I got a product Porsche 911 and several variants like 911 Turbo, 911 Targa, 911 Carrera and put 1 as quantity for 911 Turbo but nothing for the other variants, the stock level(quantity) for 911 Turbo isn't shown on the productpage?
14 years 4 months ago - 14 years 4 months ago #58821 by Mohamed Thelji
Did you change the "show_default" and "quantity" file of your "product" view ? (in "Hikashop->Display->Views").
If yes, can you make a save of this 2 files and use the Remove customization button.
14 years 4 months ago - 14 years 4 months ago #58907 by Micke_skane
I haven't changed anything in those files but I can save them in the "View".
Where/What is the "Remove customization button"?
14 years 4 months ago #58956 by nicolas
When you are on the listing of views, you have a column "remove customization" with a little icon for each row which have been customized.
14 years 3 months ago #60224 by Mighty Tower
Same problem here,.. I did all the steps mentioned above, no result.
14 years 3 months ago #60287 by nicolas
14 years 3 months ago #60288 by Mighty Tower
nicolas wrote: I suppose that you solved your problem:
www.hikashop.com/en/forum/4-how-to/60204...n-stock-problem.html
Yes i did.
Thx for the great shop!
14 years 3 months ago #62154 by Micke_skane
Now I've look into it again and I could display stocklevel on productpage but if there are just 1 product i can't order more than just 1. Even if there just 1 in stocklevel i would like to have the possibility to order more than 1!
What setting should i change for this situation?
And if there is 0 in stocklevel the textfield for number of products to order isn't displayed!
I want to have the possibility to order even if there is 0 in stocklevel.
What setting should I change for this situation?
/Micke
14 years 3 months ago #62162 by Mohamed Thelji
Hello Micke,
I think that you'll find your answer there .
14 years 3 months ago #62163 by Micke_skane
Thanks for the link but we have instead chosen to set the stocklevel to unlimited.
Time to create page: 0.116 seconds
