product description/custom field in cart view
- Christoph59
14 years 3 months ago #59944
by Christoph59
product description/custom field in cart view was created by Christoph59
how can I display the product description in the checkout cart view. Also, how can I display a product custom field (which I fill in when editing the product) in the checkout cart view and later on on the order / invoice.
Can you also help with that: how can I display the product variant/option chosen in the cart module view.
Many thanks!!
Christoph
Many thanks!!
Christoph
14 years 3 months ago #60045
Replied by nicolas on topic Re: product description/custom field in cart view
That's a lot of things
1. in the file 'cart' of the view 'checkout' via the menu Display->Views you can add the code:
<?php echo $row->product_description; ?>
after the code:
<?php echo $row->product_name; ?>
2. in the file 'cart' of the view 'checkout' via the menu Display->Views you can add the code:
<?php echo $row->CUSTOM_FIELD_COLUMN; ?>
after the code:
where CUSTOM_FIELD_COLUMN has to be replaced with the column name of the field.
3. For the invoice, you can do that in the file "invoice" of the view "product" of your back end template via the menu Display->Views.
4. The product characteristic is displayed automatically on the cart unless the "Append characteristics value to product name" option of the configuration is turned off. So you should check on that.
after the code:
after the code:
- Christoph59
14 years 3 months ago #60051
by Christoph59
Replied by Christoph59 on topic Re: product description/custom field in cart view
great thanks, will check today
christoph
christoph
- Thank you received: 1
13 years 8 months ago #93210
by paddyrolls
Replied by paddyrolls on topic Re: product description/custom field in cart view
Nicolas
Could i ask for more information
If I modify the file 'cart' of the view 'checkout' and add in my custom fields for type product, will the information be printed on the order and invoice as well.
thanks
Patrick
thanks
Patrick
- Thank you received: 1778
13 years 8 months ago #93420
by Mohamed Thelji
Replied by Mohamed Thelji on topic product description/custom field in cart view
Hi Patrick,
If you modify the file 'cart' of the view 'checkout', just your checkout will be affected. if you want to edit your invoice, you'll have to edit the good file
Hope this will help you a little.
