- Thank you received: 7
Promote additional products before checkout?
14 years 2 months ago #61681
by boopoo
Promote additional products before checkout? was created by boopoo
Hello there,
I would like to try and get customers to buy an 'add-on' product if they add 'Product A' to their cart.
For example, when a client adds a 'printer' to their cart, they would also be offered the option to add some 'printer paper' to their cart. Ideally this action would occur before getting to checkout.
What would be the best way to do that (if there is a way), or what options do I have?
Thank you in advance for your time. I appreciate you guys are all very busy.
Kind regards
Kind regards
14 years 2 months ago #61797
Replied by nicolas on topic Re: Promote additional products before checkout?
You can potentially use options:
www.hikashop.com/en/support/documentatio...ct-form.html#options
Or related products:
www.hikashop.com/en/support/documentatio...ct-form.html#related
It kind of depends on how you want to display it.
11 years 4 months ago #207535
by cipionhabla
Replied by cipionhabla on topic Promote additional products before checkout?
it is possible that a custom field type item to market a product with a price.
and to check it or uncheck in the cart.
This would be an additional product is shaped checkbox
11 years 4 months ago #207550
Replied by nicolas on topic Promote additional products before checkout?
Custom fields cannot change the price of the products in the cart, or add fees to the cart. It would require a custom hikashop plugin to be developed in order to handle what you want.
So it's not impossible to do it like that but it will require a PHP developer to help with that.
