questions ?
15 years 8 months ago #7606 by seb
Replied by seb on topic Re: questions ?
It seems I'm up to date : "You have the latest stable version : 1.4.4"
15 years 8 months ago #7608 by seb
screenshots to explain myself :
back-end
> in the display view : order by id
> product view back end
front-end :
> show.php : it's ok
> cart : it's ok
> check-out : that's not okay anymore :( image missing http://www.hikashop.com/media/kunena/attachments/legacy/images/screenshot-20110210.jpg
15 years 8 months ago #7609 by nicolas
Replied by nicolas on topic Re: questions ?
The latest version is 1.4.5. Please download it from our website (in your order page if you have a commercial version). We didn't activate yet the new version because we want to wait a few days and get some feedback from users before. The file will indicate 1.4.4 but it's really the 1.4.5
15 years 8 months ago #7613 by seb
the message thing ... it's working for other alerts but not for this one image missing http://www.hikashop.com/media/kunena/attachments/legacy/images/message_screenshot.jpg
15 years 8 months ago #7615 by nicolas
Could you give the link to your website so that we can see the problem?
15 years 8 months ago #7616 by seb
Sure I send it to you by email ..
15 years 8 months ago #7618 by seb
Just to let you know I updated ...
This is great to be able to change the popup time to continue on shopping ...
I sent you the email
15 years 8 months ago #7622 by nicolas
Correction: you will see a message only when you require activation for the user accounts. Since you don't, there is no message, it's normal.
You can't add a message without hacking in the core files of HikaShop and you'll loose your modifications when you update.
If you still want to do that, you can edit the file administrator/components/com_hikashop/classes/user.php in the function register.
15 years 8 months ago #7755 by seb
else for the characteristics .. ?
15 years 8 months ago #7758 by nicolas
Like I said in a previous post, if you download the latest version and update, that should be fixed.
15 years 8 months ago #8021 by seb
I upadtes but it didn't change a thing in the cart is shows characteristics ordered alphabetically (for characteristics)
15 years 8 months ago #8031 by seb
So I managed to implement my post code thing ... that wasn't so hard .. thanks for the help :)
15 years 8 months ago #8065 by seb
How I can change the code for + and minus buttons (html code)
<a onclick="return hikashopQuantityChange('hikashop_product_quantity_field_1',1,0,1);" href="#" class="hikashop_product_quantity_field_change" id="hikashop_product_quantity_field_change_plus" style="width: 65px;">+</a>
i want to customize the button .. but I've got a few problems with only css :(
15 years 8 months ago #8069 by nicolas
You need to create a file templates/YOUR_TEMPLATE/html/hikashop_button.php and put the code below in it :
<?php
function hikashop_quantity_render($html,$i,$max_quantity,$min_quantity){
return '
<table>
<tr>
<td rowspan="2">
<input id="hikashop_product_quantity_field_'.$i.'" type="text" value="'.JRequest::getInt('quantity',$min_quantity).'" class="hikashop_product_quantity_field" name="quantity" onchange="hikashopCheckQuantityChange(\'hikashop_product_quantity_field_'.$i.'\','.$max_quantity.','.$min_quantity.');" />
</td>
<td>
<a id="hikashop_product_quantity_field_change_plus" class="hikashop_product_quantity_field_change" href="#" onclick="return hikashopQuantityChange(\'hikashop_product_quantity_field_'.$i.'\',1,'.$max_quantity.','.$min_quantity.');">+</a>
</td>
<td rowspan="2">
'.$html.'
</td>
</tr>
<tr>
<td>
<a id="hikashop_product_quantity_field_change_minus" class="hikashop_product_quantity_field_change" href="#" onclick="return hikashopQuantityChange(\'hikashop_product_quantity_field_'.$i.'\',0,'.$max_quantity.','.$min_quantity.');">-</a>
</td>
</tr>
</table>
You can directly change the HTML code in that file and it will override the default code which is used to display the + and - buttons. That file is in your template and won't be removed when you update hikashop so you won't have any issue with it afterwards.
15 years 8 months ago #8092 by seb
And As i said .. for the checkout in the cart characteristics are ordered alphabetically ...
so nothing changed to before the update ... see screenshot ... that's the same thing ...
15 years 8 months ago #8105 by nicolas
Would it be possible to have an FTP access to your website so that we debug the characteristics ordering thing ?
15 years 8 months ago #8109 by seb
Sure ... email sent !
15 years 8 months ago #8119 by nicolas
Thanks. We'll look at that tomorrow as we won't have the time today.
15 years 8 months ago #8147 by nicolas
There was a variable name mistake. I changed the line:
$ordering = $element->characteristics[$characteristic->characteristic_parent_id]->ordering;
$ordering = @$element->characteristics[$val->characteristic_parent_id]->ordering;
in the file amdinistrator/components/com_hikashop/classes/cart.php and that solved the problem.
We'll include that in next release of course.
15 years 8 months ago #8154 by seb
Thanks a lot for that :)
Time to create page: 0.246 seconds
