Quick help - I'm sure it is easy
14 years 2 months ago #65335
by Lingz
Quick help - I'm sure it is easy was created by Lingz
Hi, I am very new to Hika Shop and having to get to grips quickly. Things seem fine, I have worked most out I need, but when I get to the product page there is no cart, nothing to click on to buy it. Am I missing something obvious, is there something I need to activate?
14 years 2 months ago #65348
Replied by nicolas on topic Re: Quick help - I'm sure it is easy
Check that the "display add to cart button" option of the Display tab of the configuration is turned on.
The following user(s) said Thank You: Lingz
14 years 2 months ago #65537
by Lingz
Replied by Lingz on topic Re: Quick help - I'm sure it is easy
Couple more queries and I am away.... having an issue with the cart. It shows add to cart, but there's no way of knowing it has added, is there a way of making a cumulative cart show? And a go to cart option show? Thanks in anticipation....
14 years 2 months ago #65729
You can publish the hikashop cart module if you want to display the cart and have it refresh automatically on your page.
You can also configure the "When a product is added to the cart" option of the Checkout tab of the configuration.
