Product Options not ordering
14 years 2 months ago #65956 by Huski
I have some options on products and one of the options is not ordering on the front-end. In the admin, I have the characteristic which were created in an order and also added ordering numbers - but when you add this characteristic to a product it isn't putting them in an order when I assign prices to each characteristic. IN the front-end it doesn't display in order either. But its fine for one of the other options I have assigned.
Go here: www.ecomad.com.au/shop-categories/produc.../category_pathway-36
And then down next to the picture where there are options:
Vegie Bed Width - this is displaying fine
Vegie Bed Length - this is not displaying correctly. How do I fix this?
14 years 2 months ago #65995 by Mohamed Thelji
Hi Huski,
I think that the problem is coming from your caracteristic values, you'll just have to :
- Update your Hikashop (if you an older version than the 1.5.9)
- Go to "Hikashop->Products->Characteristics->'Your characteristic'"
- Change your characteristic values order with the "ordering" field.
Hope this will help you.
14 years 2 months ago #66019 by Huski
This has already been done - the ordering field under characteristics has been filled in - have the latest Hikashop installed - looks like on the front-end that a query is missing an ORDER or something
14 years 2 months ago #66026 by Mohamed Thelji
Ok, so can you send me a screenshot of your characteristic ?
14 years 2 months ago #66033 by nicolas
The option "characteristic values ordering" of the display tab of the configuration must be set to "ordering" if you want to order them by that ordering column.
The following user(s) said Thank You: Huski
