product code is missing on the product detail page
14 years 1 month ago #66400
by jan2
product code is missing on the product detail page was created by jan2
product code is missing on the product detail page.
I only see the product code in the product overview.
"Default parameters for products" in the Display menu
Display product code is activated.
Br
Jan
Br
Jan
14 years 1 month ago #66431
by Xavier
Replied by Xavier on topic Re: product code is missing on the product detail page
Hi jan2,
Can you check if you have the code:
In the view "product / show_tabular" in HikaShop > Display > Views.
This is the same code used for the product overview.
You can remove the check (if), to always display the product code.
<?php if ($this->config->get('show_code')) { ?>
<span id="hikashop_product_code_main" class="hikashop_product_code_main">
<?php
echo $this->element->product_code;
</span>
<?php } ?>
- Thank you received: 1778
14 years 1 month ago #66434
by Mohamed Thelji
Replied by Mohamed Thelji on topic Re: product code is missing on the product detail page
Hi Jan,
Do you have this CSS code in your front-end CSS file ("Hikashop->System->Configuration->Display") ?
.hikashop_product_code_main{
display:none;
14 years 1 month ago #66506
by jan2
Replied by jan2 on topic Re: product code is missing on the product detail page
The CSS file is OK
and the file "product / show_tabular" is also ok.
14 years 1 month ago #66507
by Mohamed Thelji
I just wanted to tell you to remove this CSS code
14 years 1 month ago #66508
by jan2
do you mean I have to remove the complete code ?
also the CSS ?
also the CSS ?
14 years 1 month ago #66509
by jan2
it is working !
thank you
it is working !
thank you
