Help Shopping Cart will not Fullfull the order
- bomber8484
14 years 1 month ago #67821
by bomber8484
Help Shopping Cart will not Fullfull the order was created by bomber8484
I have contacted support about this issue but I cannot get Hika Shop to full fill an order. They say is is because of the wharehouse information on shipping but that is filled out. Can anyone help me on this? The site is
customflag.globalwebengine.com/
14 years 1 month ago #67925
Replied by nicolas on topic Re: Help Shopping Cart will not Fullfull the order
Having it filled out doesn't meant that it is correctly filled.
You must have configured one of the options not correctly.
Not knowing the way you set each option, we can't tell you which one is wrong.
- bomber8484
14 years 1 month ago #68441
by bomber8484
Replied by bomber8484 on topic Re: Help Shopping Cart will not Fullfull the order
Would you like me to give you a password and Login? I will send you screen grabs.
14 years 1 month ago #68713
If the system says that the problem comes from the warehouse, make sure that you selected the correct country in the country field and that the zone field is empty and that should remove the problem.
If not, please post a screenshot and blur credentials (or put fake ones).
- bomber8484
14 years 2 weeks ago - 14 years 2 weeks ago #74785
by bomber8484
This got fixed thanks. It turns out the problem was in the wharehouse the UPS shiping was only selected for Montana as a default so nothing would fulfill past that.
Last edit: 14 years 2 weeks ago by bomber8484.
