Issue For Product Price
14 years 4 weeks ago #69323 by wirthconsulting
-> I have problem regarding 'Local fractional digits' and 'International fractional digits' parameters for Currency setting in Hikashop 1.6.0 backend.
-> When I am setting both the parameters values to 0 (zero) , then products which price is under 0.5 is converted to 0.00
For e.g. 0.40 becomes 0.00 , 0.30 becomes 00 and 0.9 becomes 1 etc.
-> Kindly suggest the solution for this issue regarding zero values of product when null fractional digits.
14 years 4 weeks ago #69325 by Mohamed Thelji
I think that you'll just have to set your "International fractional" and "Local fractional" digits options to 1 and it should be ok.
Hope this will help you.
14 years 3 weeks ago #69419 by wirthconsulting
- Still there is a issue for floating values of product.
- I have set "International fractional" and "Local fractional" digits options to 1 but it will not convert floating values to decimal. so same problem will occur.
For e.g. if we have seet "International fractional" and "Local fractional" digits options to 1
then, 0.50 becomes 0.5 , 0.40 becomes 0.4
- But Actually I want to convert floating values of product to decimal values.
- Kindly suggest and advice for issue of Hikashop currency setting for convert floating values to decimal.
14 years 3 weeks ago #69437 by Mohamed Thelji
Then you should maybe set "International fractional" and "Local fractional" digits options to 2.
14 years 3 weeks ago #69563 by nicolas
Replied by nicolas on topic Re: Issue For Product Price
I don't understand what you're trying to do.
What is a "floating value" for you ? And what is a "decimal value" for you ?
