Problem with categories
14 years 2 weeks ago - 14 years 2 weeks ago #71189 by condorazul
the problem is i want my page to show categories, with its photos but i don´t want the products of this categories to be shown when i choose category listing. I´ve tried all the configurations but still showing, and if i choose other module associated and select one category wth nothing inside, then the products are not shown in its page.
If i change the module associated porducts to category it dissapears but if i click on any categori products are not displayed, i want the categories alone, then if you click in a category, the product shows.
And whatever category i click it shows all the proucts not just the products nested in one categry as it should be.
Webpage is www.heladoychocolate.es
Last edit: 14 years 2 weeks ago by condorazul.
14 years 2 weeks ago #71363 by nicolas
Replied by nicolas on topic Re: Problem with categories
Go in the menu Display->Content module, and edit your module with the id 115. There, change the "sub element filter" option to "direct sub elements" and that will do what you want.
14 years 2 weeks ago #71395 by condorazul
I´ve change it it still have one product in it. And if i click on the categories, one has 2 products, other one 1 product, but in both only one prodcut is displayed and its the same for both.
14 years 2 weeks ago #71396 by nicolas
That means that the product is attached to the main category. That's why it's still displaying on the main category page and not inside your categories. You should change its category.
14 years 2 weeks ago #71401 by condorazul
ok first part solved,
but now if i choose the category inside no product is displayed
14 years 2 weeks ago #71487 by nicolas
I don't understand your question. Can you please give more information ?
14 years 2 weeks ago #71512 by condorazul
Yes now no product is displayed when i click in the categories take a look www.heladoychocolate.es/tienda-helado-y-chocolate
I have two products in first category one in second none is displayed. If you want access ive already sent it to you
14 years 2 weeks ago #71723 by nicolas
You deactivated the option "Sincronizar con los elementos en pantalla cuando sea posible" in the associated product listing module of your menu. So the products displayed were simply the products of the parent category selected, ie the main category, ie no products. I'e turned that back on so that it displays the products of the current category.
14 years 2 weeks ago #71873 by condorazul
thank you thats why i love hikashop
