Associated products listing
14 years 2 weeks ago #71433 by holm76
Is it possible to disable this wieving ?
In some of them it is showing but not in other..
I don't want it right now
I'm using firebug, forumsearch, dokumentation and then I ask.. It's so easy ;)
14 years 2 weeks ago #71524 by nicolas
The associated product listing modules display the products on your website front end categories listing menus.
You can remove them, but you won't see your products anymore. I don't see why you would want to do that ?
14 years 2 weeks ago #71549 by holm76
It's on a category site where it is showing under the categories. I don't want it there, I have set it not to been showed, but then I got a "fail" and a hint to creat a new one.
I have set published to no and all that, but its still showing.
14 years 2 weeks ago #71745 by nicolas
You don't want to unpublish it.
You probably just want to change the "sub element filter" option of the module to "direct sub elements" so that it only display products when they are directly linked to the categories.
If you remove the module, you won't see any product at all when you click on the categories, that's why the system is telling you that it's not OK.
14 years 2 weeks ago #71756 by holm76
Yes I just want it not to been showed at category site.
Where to do this?
I have right now made it so I link to my webshop in the mainmenu, and here it dosn'd show the ass product site..
14 years 1 week ago #72001 by nicolas
The "sub element filter" option of the module can be found in the hikashop options page of your module that you can open via the menu Display>Content modules.
14 years 1 week ago #72021 by holm76
Thnaks I will look at it.
