Need to alter Invoice appearence
14 years 1 month ago #71686 by langkatech
I need to alter the invoice appearance. It would not normally be a huge problem but we have several thousand blank invoices that have a label at the bottom for the address. Not a huge expert on CSS but can muddle my way through. any suggestions on the easiest way to do this.
actually the majority of the invoice is fine I just need to add the From and Too address in the bottom of the invoice. Can I create an "invoice2" so I don't mess up the one that is there and then just replace it when I think it is working to specification?
I have included an example.
14 years 1 month ago #71993 by nicolas
You can edit the invoice file directly via the menu Display->Views for your backend template. No need to duplicate the view. If you mess it up, just click on the "remove customization" icon of that file in the views listing and that will put back the default view file.
