Add to Cart problem
14 years 3 weeks ago - 14 years 3 weeks ago #73458
by fnuus
Add to Cart problem was created by fnuus
I have a little problem with the add to cart. When i choose a product and add it to my cart i get a pop-up, so far so good. But the pop up stays for 2/3 seconds and then the popup change to full screen modus. What is happening ??
And i have a problem with back to the shop button. I put a url in the configuration tab (back to the shop url) i saved everthing, but when i choose in the "full screen" pop-up for the back to the shop button, it's goes to the home/welkom page.
What can i do to change this.
When you want to see it, you can look on www.hanons-cosmetics.eu
With friendly regards,
Fred
Fred
Last edit: 14 years 3 weeks ago by fnuus.
14 years 3 weeks ago #73628
Replied by nicolas on topic Re: Add to Cart problem
I can see that you have several javascript errors coming from other scripts on your website which are causing the popup to not function properly.
You would have to fix these. You can see the errors by opening your browser javascript error console on that page.
The continue button of the popup will just close the popup. Since you don't have the popup, it doesn't work properly. Fixing the popup will fix the button closing the button.
The continue button's url option of the config is only for the button on the checkout page.
The following user(s) said Thank You: fnuus
14 years 3 weeks ago #73957
by fnuus
Replied by fnuus on topic Re: Add to Cart problem
I find allready the problem.
I am using a Anti-copy plug-in. I have here few choices to configurate. One of them is allow/disallow frames. This must be allow frames.
But anyway, thanks for your support.
Fred
Fred
