Shipping amounts to different products
14 years 3 weeks ago #73463 by sammyboy1
Hi guys
Is it possible to allocate a different shipping amount to different products if so how do you do it? as i have some products that are heavier than others so the shipping price needs to be different throughout the products on my site
Thanks x :kiss:
14 years 3 weeks ago - 14 years 3 weeks ago #73468 by reace
I think this one can be achieved by doing the following;
System > Shipping Methods
click on 'HikaShop Manual Shipping Plugin'
Do this [add] a new Shipping Method for each different weight class..
for example;
Methods:
less then 5kg, $10.00
greater then 5kg and less then 10kg, $20.00
name the first method 'less then 5kg'
and set the 'maximum weight' field to 5kg
set the price to $10.00
name the second method '5kg upto 10kg'
and set the 'minimum weight' field to maybe 5.01kg
and the 'maximum weight' to 10kg
set the price to $20.00
now in theory.. if you have a product which weighs 1kg..
and order up 5 of these items the correct shipping amount should be.. $10.00
however if you order between 6-10 of these products then the shipping should equate to $20.00
other useful things to consider is 'zones' & postcodes..
if you are in an area where it is divided into say two zones for example.
you can setup one country zone.
and split that into multiple zones using postcodes. for example;
north zone could use postcodes from 0-5000
south zone could use postcodes from 5001-10000
now for the scenario above you could set variables like this;
method 1: north zone less then 5kg
postcodes:0-5000
max-weight:5kg
price:$10.00
method 2: north zone 5kg to 10kg
postcodes:0-5000
min-weight:5.01kg
max-weight:10kg
price:$20.00
method 3: south zone less then 5kg
postcodes:5001-10000
max-weight:5kg
price:$15.00
method 4: south zone 5kg to 10kg
min-weight:5.01kg
max-weight:10kg
price:$25.00
in your shipping methods you can have different fee's for these zones.
hope this helps.
also you can upload your shipping companies logo to the root/media/com_hikashop/images/shipping folder and set it as the logo for the shipping
provider.
Last edit: 14 years 3 weeks ago by reace.
14 years 3 weeks ago #73521 by sammyboy1
Hi Reace
Thank you so much for coming back to me so quick.
Please can you tell me once i have created my different shippings methods how do i match the product to each one
Thanks :kiss:
14 years 3 weeks ago - 14 years 3 weeks ago #73524 by reace
Well in theory... that's all u do. As long as youve set
Your location you're away. Make sure your products have weights set.
How it works is.. based on the weight of the product , the shipping method's whose pproperties best match the product Will be available on the Checkout page.
14 years 3 weeks ago #73528 by sammyboy1
Thank you will try it now x :kiss:
