Will not go to HTTPS on checkout
14 years 2 weeks ago #74789 by bomber8484
My site is StateFlagShop.com I have set this site up on a go daddy server and the ssl cert is good. I set up the entire store then got the SSL. When I click SSL in the configuration nothing happens when you check out there is no change. It does not force the domain to go to https can you help me out?
14 years 2 weeks ago #74932 by Xavier
I see that your problem is solved, I just tried on your website and I see that the checkout process is on https.
