Joomla Search Box does not find products or cats
14 years 2 weeks ago #75537 by fan4chevy
I am setting up my cart and I am finding that the joomla search box is not finding any of the products or categories.
How do I get the search box to find my products and cats?
Charles
14 years 2 weeks ago #75545 by nicolas
You need to publish and configure the hikashop products and categories search plugins.
The following user(s) said Thank You: fan4chevy
14 years 2 weeks ago #75637 by fan4chevy
Being I have you here. Do you know how I can fix the issue where I have two category links side by side as seen in this image attached.
14 years 2 weeks ago #75761 by nicolas
That's a CSS issue.
You need to add the CSS code:
.hikashop_category_list_item, .hikashop_product_list_item { float: none !important; }
in the front end CSS file of HikaShop that you can edit via the interface in the Display tab of the configuration.
14 years 2 weeks ago #75771 by fan4chevy
That worked, but what part makes the category default to show subcategories rather than just a link and then when you click the link it then opens the subcategories.
See attached image on how the bmx parts link automatically shows the sub cats.
14 years 2 weeks ago #75784 by nicolas
It's the option "Show sub categories" of your module.
14 years 2 weeks ago #75806 by fan4chevy
Where is this located. I put no child in areas I could find it and it never changed it, so I must be in the wrong place.
14 years 2 weeks ago #75937 by Xavier
It's in HikaShop > Display > Views, edit the module displaying these elements and change the value of the option "Show sub categories"
