Some products donot display description
14 years 2 weeks ago #75557
by ghumchor
Some products donot display description was created by ghumchor
Hello All,
I am very new to hikashop and facing several problems. Some products at my hikashop do not display description and values properly.
an example is her washedupjewelry.com/rings/product/93-sun...ll-ring#.UJ6S14ciGbg
My joomla version is 1.5.26 and hikashop version is 1.5.8
Can anyone please tell me why this is happening.
14 years 2 weeks ago #75786
Replied by nicolas on topic Some products donot display description
That's because your characteristics are not setup properly in your product.
Before HikaShop 1.6.0, you had to add all the characteristics at once in a product, otherwise it would work properly.
So you need to:
1. Delete all the variants of the product on the listing of variants that you can access via the button "manage variants" on the product edition screen.
2. Delete the characteristics of the product.
3. Save the product.
4. Add the characteristics again.
5. The system will regenerate all the variants automatically and you should be able to see the dropdowns properly on the front end.
So you need to:
