- Thank you received: 2
Custom Field on Display Module
- dynamicvitality
13 years 11 months ago #76034
by dynamicvitality
Custom Field on Display Module was created by dynamicvitality
I have copied instructions according to this post:
www.hikashop.com/en/forum/4-how-to/53515...-module-display.html
I have added a custom field "teachings" to my product, and I have added <?php echo $this->row->teachings; ?> to the listing_img_title vie file, but still only the image and the product name are showing up on the front end.
Any help would be appreciated.
Site is at retreatwell.com/index.php ("Products" are on the right "featured instructors" and "featured centers"
13 years 11 months ago #76165
by Xavier
Replied by Xavier on topic Custom Field on Display Module
Are you sure that you have edited the good view ? Is you display module parameter set to div > image and title ?
Could you give us a screenshot of your custom field parameters ?
- dynamicvitality
13 years 11 months ago - 13 years 11 months ago #76235
by dynamicvitality
Replied by dynamicvitality on topic Custom Field on Display Module
Ok, here are the images:
The custom field page:
imgur.com/lRcIE
The Products with custom field: (Only put it on 3 so far, but migt need to reload mainpage to get one of first 3 -- as they are all in random display)
imgur.com/Z0W4O
The modules settings:
imgur.com/J0RSe
And the edited view text: (Notice i put the custom field text in 2 separate places -- after trying only one -- and still doesnt work):
imgur.com/GkUNq
Thanks again for your help!
imgur.com/lRcIE
imgur.com/Z0W4O
imgur.com/J0RSe
imgur.com/GkUNq
Last edit: 13 years 11 months ago by dynamicvitality.
13 years 11 months ago #76467
Replied by nicolas on topic Custom Field on Display Module
You need to enter a text in the custom field for each product if you want your modification to display that text for each product.
Also, make sure that you're editing the product/listing_img_title file for your frontend template and not another template.
- dynamicvitality
13 years 11 months ago - 13 years 11 months ago #76491
by dynamicvitality
Thanks Nicolas,
I wasn't expecting it to show for all at this point, but it inst showing for the 4 that do have custom fields. Are you saying unless all of the products custom field have text, that is somehow wont show up for any of them? And to your second point: I don't understand. How could the img_title file be for anything but the frontend template? I am running only 1 template on my site.
UPDATE: Now I see what you are talking about. It works. Thank you for the excellent customer service.
