Order status language translation problem
14 years 1 week ago #77150
by abbakhan
Order status language translation problem was created by abbakhan
Hi!
I cannot edit/translate the order status. The descripton field is normal, containing a text area, but there is no text field to translate the "Status name"
please view the image attached.
14 years 1 week ago #77189
by Jerome
Replied by Jerome on topic Order status language translation problem
We made a fix for the order status.
Please re-download HikaShop 2.0, it would fix the problem for the order status creation.
After that, if you want to edit or translate an order status, please you the Language override.
CREATED="created"
CANCELLED="cancelled"
etc...
CREATED="created"
etc...
14 years 1 week ago #77220
by abbakhan
Replied by abbakhan on topic Order status language translation problem
I still cannot edit the new order status that I have created. I did not
understand the following part of your instruction:
CREATED="created"
etc...
Could you be more specific about that?
Could you please confirm that I have downloaded Hikashop as the latest
version here:
www.hikashop.com/en/account/your-orders/...r/show/cid-5684.html
if that is the correct one? As the package does not contain any
information about version, I'm not sure if that is the correct/latest
version.
Thank you!
CREATED="created"
etc...
version here:
version.
Thank you!
14 years 1 week ago #77223
by Jerome
When you bought an HikaShop license, there is no version attached, you can download the latest version of HikaShop still your license is valid.
You can go into " Your account / Your subscriptions " to download the latest version.
In your backend, you can check your HikaShop thanks to the menu "Update / About".
Here the documentation about translations :
www.hikashop.com/en/support/documentation/faq.html#translation
14 years 4 days ago #77658
by abbakhan
Thank you for letting me know about the language override function!
Would you please be kind to advise about, how can I translate a new "Order status" lets call it "Packaging" created by me (not the Hikashop's default "Order Status")
14 years 4 days ago #77678
by Xavier
Replied by Xavier on topic Order status language translation problem
I think that you just have to add the translation in the language file, Packaging="Packaging".
HikaShop > Configuration > Languages.
14 years 4 days ago #77803
by abbakhan
You know and I knew that that cannot work. This is a bug. You know that its supposed to be translated in the edit interface (the image I have provided you in my first message), but its not. This problem has appeared after the last update. I did add couple of Statuses in previous version and did not have any problem with translatin.
14 years 4 days ago #77850
by Jerome
Did you re-download HikaShop 2.0 ?
14 years 3 days ago #77876
by abbakhan
Yes I have updated 3 days ago and I suppose after that no new version has been released
14 years 3 days ago #77945
by Jerome
Right, the previous fix didn't fix all of the problems.
I have made another tests and I have found your specific problem, so, the new package that I have just put online, would fix it.
Sorry for the inconvenient.
The following user(s) said Thank You: abbakhan
