tar.gz problem with installation
13 years 11 months ago - 13 years 11 months ago #81318 by Lemon Tree
I am trying to intall hika shop essential in an xampp environment, but I just get a blank screen. (Joomla 3.0.2 php 5.4.4, memory_limit 128M). Have done some quick searches, and it appears that it may be an xampp & tar.gz problem. I read that I could convert the tar.gz file to a zip file using 7zip, but I can't seem to manage to do it :( Not familiar with this issue. Is it possible to get the file in .zip format, or any other suggestions?
(BTW, this is a fresh install. I am assuming I don't have to install the Starter version first??)
Last edit: 13 years 11 months ago by Lemon Tree.
13 years 11 months ago #81373 by Jerome
We have fixed an potential issue with the package download. So if you had a problem opening the tar.gz file, if the file was "corrupted", you could redownload it to fix the problem.
If your problem is a really a tar.gz issue, you can add a parameter in the download url in order to get the zip version.
Just add the "?ext=zip" at the end of your download url like:
level-starter.html?ext=zip
The following user(s) said Thank You: Lemon Tree
13 years 11 months ago #81558 by Lemon Tree
Many thanks, Jerome. I tried downloading the tar.gz file again, incase the previous one was corrupted, but still got the dreaded white screen, so it looks like it is a problem with xampp and .tar.gz. Thanks for the instructions to get the zip version, which installed with no problems :)
