indexing number products missing
13 years 11 months ago - 13 years 11 months ago #83392 by mariussport
Hi, when i produce more than 20 articles in a category, (hikashop products back-end) than they are not visible, (only when you know them and use search)
This is what's missing (see the documentation)
# : An indexing number automatically assigned for ease of reference.
In the category list it's OK
Any idea?
greetings, Marius
Last edit: 13 years 11 months ago by mariussport. Reason: back end view
13 years 11 months ago #83439 by Jerome
Which version of HikaShop are you using ?
Could you provide a "bigger" screenshot. Your current screenshot just indicates that there are 7 products.
13 years 11 months ago - 13 years 11 months ago #83484 by mariussport
Hi Jerome,
Hikashop Business 2.0
Attachment is a new image from a "products list" Note: The previous image was was of a "Category list"
pro.mariusklabbers.nl/index.php/product-...e/category/40-discus
Marius
13 years 10 months ago #83563 by Jerome
And what's the problem ?
I see 11 products in your screenshot and 11 products in the front-end: pro.mariusklabbers.nl/index.php/product-...ory/45-orentatieloop
Where is the category with more than 20 products ?
Where is the problem ?
13 years 10 months ago - 13 years 10 months ago #83572 by mariussport
hi, Thanks for your answer,
I found the solution. The point is the monitor wide. I'am working with two monitors.
normal working in Hikashop: on the 1152 px wide monitor: NOT visible an indexing (page) numbering, when i move the page to the other monitor and make it wider, it wil show as a miracle!
on the 1440 px monitor its alright.
Visalistion clearly on the the attachment, see it please. (monitor wide 1440px)
regards, Mmarius
marius
Last edit: 13 years 10 months ago by mariussport. Reason: attachment
13 years 10 months ago #83576 by Jerome
This CSS problem has been fix in a recent package of HikaShop 2.0
By updating HikaShop and refreshing your browser cache (in order to reload the CSS files with the new one), it should fix the problem.
13 years 10 months ago #83577 by mariussport
Hi Jerome,
that was what want to send you, see the attachement. You are very quick with the solution, so its fixed! thanks very much.
regards,
Marius
