2 Issues with side bar carousel
13 years 10 months ago #84605 by Rollerskate
On my side bar widget carousel that you can see here:
www.therollerskate.com/component/hikasho...oduct/563-heavy-snow
Every once and a while, two items overlap each other, but it's not every one. Very strange, do you know what might be causing this?
Also, when an item is click, it doesn't go directly to a product page, but goes to the home page with the product at the bottom. How can I fix this?
13 years 10 months ago #84869 by Eliot
Hi there,
Could you please post a screenshot of your module configuration? I'd like to know what you it to looks like.
Also, about the link, the problem is probably related to the menu linked to this module :)
13 years 10 months ago #84886 by Rollerskate
More Photos Module settings screenshot attached.
And what do you mean by the "menu linked to this module"?
13 years 10 months ago #84888 by Rollerskate
I figured out the menu assignment thing, however, it's doing weird things.
If I go here, everything looks fine:
www.therollerskate.com/component/hikashop/product/627-the-trees
But when I select something in the slider, it looks bizaar:
www.therollerskate.com/photos/product/446-pier
(still having problems with images stacking)
13 years 10 months ago - 13 years 10 months ago #84898 by Eliot
Hi there,
I just checked your css and the issue is because of a rule you added:
ul li a { font-size: 1.2em; line-height: 1.8em; }
This code increase the size of your font and the calculated size of the sliding module cannot adapt to this... So you just have to override or delete this css and the module will works well :).
To edit the css you have to go in System>Configuration>Display and edit the front end css file.
About the menu, I meant the bottom left option called "menu", you have to select there your category listing :).
EDIT: try with line-height: 1em; and no font-size and you'll see it's working ;)
Last edit: 13 years 10 months ago by Eliot.
13 years 10 months ago #84907 by Rollerskate
Ok, I found the Displays under Views, but there are a lot of files in there, which one should I edit?
13 years 10 months ago #84916 by Eliot
Actually you don't have to edit any view, it's just a css issue.
Adding something like that to your front end css file should solve the problem:
.hikashop_main_carousel_div hikashop_subcontainer ul li{ font-size: 1em; line-height: 1em; }
13 years 10 months ago #84933 by Rollerskate
not exactly sure where you mean then.
13 years 10 months ago #84957 by Jerome
You would found information about CSS styling in our FAQ:
